It is currently Thu Jul 24, 2025 6:17 am
 Post subject: Brakeline fittings
PostPosted: Thu Oct 20, 2011 8:53 am
Where can I buy imperial fittings to make the new lines for my booster?
And does anyone know if it will work with some left over line from a recent trailer project I have?
Cheers Cal
'63 850/1100 + more cooper goodies
PostPosted: Thu Oct 20, 2011 9:13 am
Just walk into a brake store like ABS.
They'll have them.
PostPosted: Thu Oct 20, 2011 12:13 pm
What size pipe did you use on the trailer?
PostPosted: Thu Oct 20, 2011 1:04 pm
Its 5mm OD
PostPosted: Thu Oct 20, 2011 2:26 pm
Mini brake lines are 3/16" (4.75mm) OD... not 5.0mm.
Most fittings are 3/8 UNF but the tandem M/C and `FAM' valve on later cares have M10 threads.
PostPosted: Thu Oct 20, 2011 4:21 pm
thanks doc, i checked the booster and its all unf so i picked up some line and fittings from abs.
ill have the lines ran and bled by the tour :)
