It is currently Fri Aug 01, 2025 1:08 am
PostPosted: Sat Oct 22, 2011 11:12 am
The fuel in the van seems to dry up after running for a while at temp. Investigation finds no fuel getting to carby. Is this caused by heat from the manifold, if so what can i sheild the fuel pump with? Fuel pump does work.
PostPosted: Sat Oct 22, 2011 2:37 pm
it should have heat sheild on it from new, I think.
PostPosted: Sat Oct 22, 2011 2:45 pm
They never came with a heat shield. You can wrap the exhaust and wrap the fuel pipes to reduce the heat.
PostPosted: Sat Oct 22, 2011 6:27 pm
Fuel vapour locks on a mini is not a common thing even on the hottest of days.
Yes you can wrap it in heat shield cloth but why is it vapour locking ???
Is it an aftermarket fuel line that is too close to the exhaust ??? Is the ignition timing properly set ???
Mike
PostPosted: Sat Oct 22, 2011 7:25 pm
chuck the mechanical pump and put an electric under the back
PostPosted: Sat Oct 22, 2011 7:38 pm
= no more vapour lock, because the fuel is then under pressure everywhere upstream of the pump (which is down the back, and cool).
PostPosted: Sun Oct 23, 2011 7:00 am
I would say for fuel pump needs replacing as a good mechanical pump has plenty of pressure
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Oct 23, 2011 7:16 am
Probably the little flap valves in the pump if it's a goss mech pump.
Or there's a bit of poop under one or both of them. They will still pump fine like this but only when there's fluid in there, once some vapour gets in they wont lift (same problem if priming from dry). New valves solves the problem each time :D
cheers,
