twin su carb linkage help https://www.ausmini.com/forums/viewtopic.php?f=2&t=73691 |
Author: | wolfmini [ Sun Oct 23, 2011 5:13 pm ] |
Post subject: | twin su carb linkage help |
Hi, trying to work out if i have put this together right? im not sure where the centre spring goes, atm i have it connected to the accelerator clamp and if the linkages are the right way ![]() ![]() ![]() sorry pics aren't the best laptop camera |
Author: | Morris 1100 [ Sun Oct 23, 2011 5:17 pm ] |
There is normally a little tag that the spring attaches to. The tag sits where you have the spring. I will see if I can find a photo or something... |
Author: | wolfmini [ Sun Oct 23, 2011 5:19 pm ] |
but the accelerator clamp still goes through that hole? and the tag attaches to the clamp? |
Author: | Morris 1100 [ Sun Oct 23, 2011 5:32 pm ] |
Actually you have the wrong cable bolt. Yours is a choke cable one not a throttle one. This is the correct one and it shows the spring link (AUD3152) ![]() It goes in the same place and it has a split pin in the end of it. |
Author: | wolfmini [ Sun Oct 23, 2011 5:34 pm ] |
thanks morris 1100, ill have a look in the spare parts bin |
