economy question...
https://www.ausmini.com/forums/viewtopic.php?f=2&t=7378
Page 1 of 2
Author:  djstib [ Fri May 20, 2005 10:48 am ]
Post subject:  economy question...
can u guys list what size engine u have.... 1 or 2 tanks and how many miles a tank lasts u
i have 2 tanks in a 1330 but i dont know how long they last and the fuel gauge dont work so im always filling up
Author:  benjamin [ Fri May 20, 2005 10:59 am ]
whdont you fix the fuel guage :)
Author:  snowie [ Fri May 20, 2005 11:03 am ]
I have a 1100 clubman which has a 24 litre fuel tank, i fill up a full tank once every week but it depends on how much and how hard you drive it. Check the wires going to fuel tank and make sure they are all connected and cleaned properly and if they are then you might be looking at a new guage or you might have to check the float in the tank.
Author:  fuzzy-hair-man [ Fri May 20, 2005 11:06 am ]
Not sure my odometer stopped working
but 998 and 1 tank usually takes twenty litres when empty.
for that I get about 200 - 220 ish maybe?
When the fuel guage stopped working and I drove it to Canberra I worked on filling it up at least every 200 kms
I might also add the little green girl did Armidale to Canberra (that's 800kms) with only one stop and whilst the temperature sometimes climbed it was OK as long as I wasn't stopped and idling too long. (Is there a smilely for proud parent type thing)
I was very proud of her it was a very good effort and then she did the return trip with my parents and there was no problems that way either. (Another proud parent smilely)
Author:  danidad [ Fri May 20, 2005 11:11 am ]
new 850's were suposed to do very close to 50 mpg.
Author:  Harley [ Fri May 20, 2005 11:13 am ]
I got an estimated 100ks from my last fill up, to when my car stopped.
When you people fill up, where do you stop? When you can see the fuel or when it cuts out or what?
Author:  fuzzy-hair-man [ Fri May 20, 2005 11:46 am ]
That's 17 km / litre is it? :shock: That's impressive :o
Author:  cush [ Fri May 20, 2005 11:53 am ]
Image 50 miles per gallon = 21.2571853 kilometers / litre
Author:  danidad [ Fri May 20, 2005 11:56 am ]
check out the brain on cushy ...nice work
Author:  cush [ Fri May 20, 2005 11:57 am ]
check out the calculator on cushy... ;)
The Google Calculator
Author:  danidad [ Fri May 20, 2005 11:58 am ]
ok then next question ... what distance does that 3 in the 7th place right of the point equal??
micrometer time not hammer time
Author:  Harley [ Fri May 20, 2005 11:58 am ]
Or 4.7 litres per 100 kms for us people who don't understand MPG.
Author:  cush [ Fri May 20, 2005 12:00 pm ]
Image.0000003 * 1 kilometer = 0.3 millimeters
Author:  fuzzy-hair-man [ Fri May 20, 2005 12:14 pm ]
21.164021 or thereabouts using US gallons the one I worked out previously was using UK gallons (I figured that's where the 850 was made originally so that is probably the quoted figure :?: )
If it is 20km / litre that is even more impressive
Conversions from:
http://www.onlineconversion.com/volume.htm
Author:  danidad [ Fri May 20, 2005 12:21 pm ]
ohhhhh the plot thickens the figures i quoted was from BMC so therefor UK measure
