It is currently Sun Aug 17, 2025 7:02 am
 Post subject: Engine Balancing
PostPosted: Sat Oct 29, 2011 8:35 pm
I have had my engine balanced when I first built it
The rubber in the Harmonic Balancer is a little preished and I want to get the balancer rebuilt.
I was wondering if this would change the over balance of the engine or would things be ok if the balancer is re balanced again
and can you change say a single conrod and be ok if its the same weight with out re balancing the whole engine again
Thoughts would be appreciated
Kiwiinwgtn
 Post subject: Re: Engine Balancing
PostPosted: Sat Oct 29, 2011 8:42 pm
It may look perished outside but looks are deceiving. Trim it flush with a razor blade then take another look.
I was wondering if this would change the over balance of the engine or would things be ok if the balancer is re balanced again.
It will be OK, the balancer (misnamed item if ever there was one- should be called a harmonic damper) is/should be rebalanced by whoever rebuilds it.
and can you change say a single conrod and be ok if its the same weight with out re balancing the whole engine again.
Sure can, no problem.
My 1412 stroker has 3x rods out of a busted Melburnian 1275, and a 4th one I got from GR. But yeah I balanced them the same within 1gm.
Kiwiinwgtn
PostPosted: Sun Oct 30, 2011 5:38 am
Hey, if you remember can you let me know if you ever find out a local price/supplier for a rebuild? Been meaning to get to that job for ages but have never got off my butt to compare a retread to buying new.
Oh and didn't see you up here on the weekend....or if you were there I completely missed you!
PostPosted: Sun Oct 30, 2011 9:00 am
might cost you a bit extra, but you can post them to "Ross Performance Engine Parts" in Sydney. $180 a couple of years ago
maybe not cheaper than buying a newie, but maybe you don't want a newie
PostPosted: Sun Oct 30, 2011 7:23 pm
Watch what you buy new.
People on here and others on track have had trouble with Romac balancers, they can self destruct..
Minis Plus has nice blingy MED ones, I use one on my 1412 and many people (GR included) race with them.
http://www.minis.com.au/minis/catalog/p ... cts_id=912
PostPosted: Tue Nov 01, 2011 7:25 pm
Thanks for the replys
There is guy in Nz who repairs them Harmonic Damper Rebuilds Ltd.
I have not used him personally but his feedback is good.
I may go the MED path as its only a little more exspensive.
Didn't make it to Hastings Labour Weekend does not work for us as we plant our organoic garden over that weekend otherwise we have no fresh veges for the summer
Sounds like it was good event
Ta
Bernard
Users browsing this forum: No registered users and 309 guests
