Oiling the Dizzy
https://www.ausmini.com/forums/viewtopic.php?f=2&t=73825
Author:  phillb [ Sun Oct 30, 2011 4:55 pm ]
Post subject:  Oiling the Dizzy
I have an Aldon modded 45D with electronic ignition.
I have read in the handbook about adding a few drops of oil into the dizzy to lube the weights.
Do I need to do this on this dizzy?
In the pic below where should I add oil, I can just see the weights thru the opening near the top.
Author:  drmini in aust [ Sun Oct 30, 2011 7:19 pm ]
The usual incantation from Mr Lucas was to add a few drops of oil onto the end of the shaft, under the rotor. Dizzys used to have a bit of felt in there.
Oil runs down the shaft, lubes it and (perhaps) gets flung out onto the weights.
With Pulsar dizzys I take apart, pull the weights, off then grease their pivot pins with Castrol HMP grease.. as they had originally.
Author:  Convertible Mini [ Mon Oct 31, 2011 6:13 am ]
Post subject:  45D
I might add that your Dizzy is actually a 43D4. A 45D4 would have Vacuum Advance.
Author:  phillb [ Thu Nov 03, 2011 6:27 am ]
Post subject:  Re: 45D
It looks like it used to have vacuum advance as there is a cover plate screwed over the opening where vac advance would be (added by Aldon i presume) How do I ID it to be sure?
Now thinking about it I could probably access and oil the weights if I removed that plate.
So should I try and oil them or just leave it alone. When I turn against the rotor I can feel them operating freely.
Author:  drmini in aust [ Thu Nov 03, 2011 7:00 am ]
43D and 45D have the same body- but the 43D has that tin cover on there to cover the hole.
Usually the Lucas body has 43D or 45D stamped on the side when built.
Author:  phillb [ Thu Nov 03, 2011 2:46 pm ]
Ok well then it is 43D. I just assumed the cover was something Aldon added.
Thanks Doc and Convertable Mini
