It is currently Sun Aug 17, 2025 4:47 pm
 Post subject: 1/4 vent latch pin
PostPosted: Mon Oct 31, 2011 8:58 pm
How do you remove the 1/4 vent latch pin without damaging the latch?
Tried drilling one out but it is tiny and things end up stuffed. There's nothing to grab cause the pin is in so far.
If I can't sort it out I'll have to change 1/4 window I guess, but would prefer not to have to.
Thanks for the help.
Now with 2 extra ports!
PostPosted: Mon Oct 31, 2011 10:11 pm
Done this job the other week i just got a small flat screw driver and a hammer and tapped it out from other side
And with the one i was taking off i ended up cutting with hacksaw along the pin till i seen the pin then tapped it out
PostPosted: Mon Oct 31, 2011 10:18 pm
So it should go straight through then? The other sides looks like it's chromed which would have been done before the pin was put in.
Will give it a go though.
Thanks!
PostPosted: Tue Nov 01, 2011 7:54 am
Thanks!
NO,
The pin will not go straight through.
Has to come out the way it went in....
Not an easy job.
Dave
PostPosted: Tue Nov 01, 2011 8:21 am
I drilled mine out with a small drill bit and a variable speed drill. Keep the speed slowish and take your time. And yes mine also did not look like they would push all the way thru.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Nov 01, 2011 9:53 am
I tapped it out from chrome side and it came out the side you see the pin just enough so pliers could grab it
My spring inside was stuffed inside that handle
PostPosted: Tue Nov 01, 2011 11:44 am
You can buy new pins and springs from Minisport in Adelaide.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Nov 01, 2011 1:16 pm
I cut the whole quarter window out of a door with a hack saw at northern road wreckers penrith cause the 3 screws were rusted well got it for $20
PostPosted: Tue Nov 01, 2011 6:37 pm
All good advice and ideas there guys!
I got a new pin n spring from living legend Sir John Schmidt!
Thanks!
PostPosted: Tue Nov 01, 2011 6:48 pm
Yes john is a legend with the amount of bargins ive got there in the last few weeks
Users browsing this forum: No registered users and 333 guests
