It is currently Thu Aug 14, 2025 2:04 am
 Post subject: Speedo Repairs
PostPosted: Sat Oct 29, 2011 11:47 am
So, I was wondering why the odometer wasn't working when I bought the car.
Cable broken?(didn't drive the car) Missing parts........?????????????
Image[/img]
After searching & reading several topics on speedo's, Doc & morris 1100 said all Aussie motors had the same gearbox pinion drives & the speedos were changed to suit the different diff ratios.
Does anyone have a list of the different TPM/TPH that were available here on Aus?
My question is, as i don't have any other clubman 2 or 3 gauge dash to compare with, can i simple find a dash with the correct TPM/TPK and swap over the missing bits? or I'ld be guessing it would be easier to pull out mine and swap in a working one?
My other challange is that I'm most likely going to swap from my current 3.44 diff to a 2.9 & I'm running 12" rims!
Cheers Shane
PostPosted: Sat Oct 29, 2011 8:02 pm
This is a good site to start with
http://www.guess-works.com/Tech/
You will need the pinion and speedo drive from the correct model (check out the link above it will calculate the one you need)
the 2.9 diff came out of a 12 inch wheel car, so it will mostly be pay the money and get the right bits which are exspensive by the way.
I need to sort out mine and are going to draw the cogs up in cad and get them plastic printed on a 3d printer. Its on the last thing to do list. Mine is running 3.1 diff on 10 inch wheels witha 1275GT speedo which is a little harder to sort.
I have a TPI calculator some whare if you find the Guesswork link dosn't sort you out
Kiwiinwgtn
PostPosted: Sat Oct 29, 2011 8:08 pm
I thought the bit made made the speedo work depending on what diff, was down in the gearbox/diff somewhere??
PostPosted: Sat Oct 29, 2011 8:10 pm
correct, they are both in the gearbox
PostPosted: Sat Oct 29, 2011 8:13 pm
Only in UK (later) cars, not in Oz.
All Oz cars had the same speedo drive pinion and gear in the main gearbox- different speedo heads were used for the different diff ratios.
eg Cooper S (3.44 diff and 10" wheels) speedo head is 1280 turn per mile.
I have had 2 bigwheel Moke 140KMH speedos- one is 800turns/km and the other 860.
Remember Oz production ceased in 1978- most of this plethora of strange drive gear combinations in the gearbox happened in UK after that (ie the Rover era).
PostPosted: Sat Oct 29, 2011 8:43 pm
I may have labelled the tread wrong, as the speedo actually works when spun, ie it give a kph reading, however the odometer fails to turn for the obvious of missing gears.
Doc as you can see on the 3rd photo down it's a 780 TPK/TPM, which is why I included that photo. Do you know if the drive gears for the odometer are common across the Aus speedos?
Kiwiinwgtn, yeah I've been checking out Guessworks alot recently due to a couple of gearbox rebuilds in the very near future and have sus'd their Tech info, but it doesn't cover the Aus stuff unfortunately. I think I'm still going to have to change the gearbox worm & pinion drive gears to match the 2.9 diff, I'ld like the speedo to be half acurate, ha ha ha, if that's possible. I'm too used to driving to a tacho not a speedo in a mini!
Cheers Shane
PostPosted: Sat Oct 29, 2011 8:49 pm
Yep it is 780 turns/km, = 1263 turns/mile. = near enough for a 3.44 diff (Cooper S was 1280).
All the odometers work in a similar fashion (ratchet and pawl) the differences are in the worm gear (you can see) and the driven gear + pawl it drives (I can't see).
I would pack it off to a speedo place for repair.
[edit] If you can find a late Oz Clubby 998 speedo (they used 3.44 diff mostly) rob these bits from it..
PostPosted: Sat Oct 29, 2011 9:22 pm
Heres a pic of a OZ speedo
looks like a cam is mssing on yours
PostPosted: Sat Oct 29, 2011 9:24 pm
Thanks for that Doc, I'll keep an eye out for 1 in the For Sale section!
I thought the made in UK was a little odd for an Aus speedo. Also mine has the quick clip style speedo cable connection while yours is a threaded one. That's what you get when you buy someone elses project, a lot of unknowns.
Cheers Shane
PostPosted: Sat Oct 29, 2011 9:35 pm
All Oz fitted speedos were made in UK up until around 1968-69, when Mini K and Mk2 S etc got Oz ones.
My 2 Moke 140KMH speedos are both made in UK.
PostPosted: Sun Oct 30, 2011 9:03 pm
I have found a OZ Speedo in a box of bits if you want a pic of the cam etc
PostPosted: Wed Nov 02, 2011 2:53 am
Hi kiwiinwgtn, pics would be great! Guess-works don't really have a photo that I can see.
Cheers Shane
PostPosted: Wed Nov 02, 2011 6:52 pm
hope this helps
Users browsing this forum: No registered users and 209 guests
