It is currently Sun Jul 27, 2025 2:44 am
PostPosted: Fri Nov 04, 2011 6:04 pm
Does anybody else have a mini with no control box/voltage regulator?
I have just replaced the loom in my mini with a uk one but when I connect the battery terminals the motor starts, even without a key in the ignition! okay, I'm guessing that is not good.....
I pulled the white/red wire from the solenoid - ok now it doesn't crank the starter motor so I went looking at the ignition switch and rechecked the wiring diagram. It all looks wired up right but I don't seem to have a control box or voltage regulator.....
I remember when I pulled the old wiring out there was a big tangled mess of brown wires all soldered and twisted together that were just wrapped in electrical tape in the engine bay. I thought it was dodgy at the time but now i wonder if they were supposed to be going to the missing control box. the car still ran so I thought it was just more evidence of the PO's dodgyness.
So, do I just take most of the brown wires off the solenoid a la the old wiring, or should I try source and put the voltage regulator in there?
PostPosted: Fri Nov 04, 2011 6:08 pm
Since 1972 or so, every Mini had had no voltage regulator. it is built into all the lternators now.
The tangled wiring you have is obviously where they have done a `regulatorectomy' to convert (from generator) to fit a current alternator.
With these there is a thick brown wire (or 2) from the solenoid's battery terminal to the alternator, and a thin brown/yellow wire from the alternator to the ignition light in the speedo. That is it...
PostPosted: Fri Nov 04, 2011 6:46 pm
Regulatorectomy.... Love it!
So my eager starting wiring problem is probably due to something else. Unless anyone has any ideas i guess i might have to concede defeat and call the auto electricians.
PostPosted: Sat Nov 05, 2011 9:20 pm
There's obviously a mismatch somewhere. The solenoid COM wire (i.e. the wire you momentarily send power through to trip the solenoid) is obviously connected to an always-on power source or it is shorting on one enough to switch the solenoid over which in turn sends power to the starter motor.
PostPosted: Sun Nov 06, 2011 8:14 am
You were right Tom,
I searched through the forum and found a post '72 wiring diagram and made the necessary alterations and I think I may have sorted it. I'm just waiting fir the battery to recharge.
