It is currently Fri Aug 01, 2025 3:50 am
 Post subject: My Nipple broke
PostPosted: Sat Nov 05, 2011 7:10 am
Any one got a solution to my problem:
The grease nipple for the top ball joint on the front hub has snapped, has anyone succesfully removed the remailing thread and re-tapped the cast?
PostPosted: Sat Nov 05, 2011 8:01 am
Yeah I've done it by drilling to the thread's root diameter then cleaning the thread out with a tap. Can't remember the size though!!
Forget little ezy outs- they are a waste of time IMO. :wink:
PostPosted: Sat Nov 05, 2011 9:55 am
yea - the ezy out didnt work, it just twisted while the cast hub laughed at it :)
PostPosted: Sat Nov 05, 2011 9:57 am
I've used small ezi outs before after deepening the thread in them with a dremel cutter. As bought they are too shallow and don't bite.
PostPosted: Sat Nov 05, 2011 1:14 pm
I have a torx bit which just happens to be a hammer fit into the grease channel of the nipple, so i didn't even need to drill a hole. Just tapped in the torx bit and unscrewed the nipple. The thread in the hub was fine so i just screwed in a new nipple
