It is currently Sun Jul 27, 2025 8:43 am
 Post subject: Moke specs
PostPosted: Fri May 20, 2005 7:19 pm
Someone with a Moke be able to help me out?
Need width and length of bonnet
width and height of front grille panel
Anyone able to help me out???
thanx in advance
Old car = www.allmtr.com
New car: 500kg Moke with 500hp
PostPosted: Fri May 20, 2005 7:51 pm
Bonnet is 64cm from front edge to back edge (ecluding hinges), 94.5 cm from side to side.
For the "grille panel" do you mean the size of the grille on a removable front grille type Moke? Or do you mean with the whole front panel cut out like this?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri May 20, 2005 8:43 pm
Think width is already gonna be dictated by motor....
How high is the front panel?
BTW thanx for the help and gotta love the response time 8)
PostPosted: Sat May 21, 2005 10:13 am
No problem!
Front panel is 58cm from top to bottom, or 51cm from top of front subframe above the tie bars.
What are you thinking of dropping in there? :)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat May 21, 2005 7:28 pm
So you wandered over here did you? What are you putting in this or aren't you saying yet? :D I better go and check on PF and see if you have revealed it yet.
Chris
Everything I like is either
PostPosted: Mon May 23, 2005 2:17 pm
Another Subie 8)
Users browsing this forum: No registered users and 114 guests
