Moke specs
https://www.ausmini.com/forums/viewtopic.php?f=2&t=7396
Author:  Moke of Death [ Fri May 20, 2005 7:19 pm ]
Post subject:  Moke specs
Someone with a Moke be able to help me out?
Need width and length of bonnet
width and height of front grille panel
Anyone able to help me out???
thanx in advance
Author:  bnicho [ Fri May 20, 2005 7:51 pm ]
Bonnet is 64cm from front edge to back edge (ecluding hinges), 94.5 cm from side to side.
For the "grille panel" do you mean the size of the grille on a removable front grille type Moke? Or do you mean with the whole front panel cut out like this?
Author:  Moke of Death [ Fri May 20, 2005 8:43 pm ]
Think width is already gonna be dictated by motor....
How high is the front panel?
BTW thanx for the help and gotta love the response time 8)
Author:  bnicho [ Sat May 21, 2005 10:13 am ]
No problem!
Front panel is 58cm from top to bottom, or 51cm from top of front subframe above the tie bars.
What are you thinking of dropping in there? :)
Author:  Chris [ Sat May 21, 2005 7:28 pm ]
So you wandered over here did you? What are you putting in this or aren't you saying yet? :D I better go and check on PF and see if you have revealed it yet.
Author:  awdmoke [ Mon May 23, 2005 2:17 pm ]
Another Subie 8)
