It is currently Sat Jul 19, 2025 4:21 pm
PostPosted: Sun Nov 06, 2011 4:37 pm
i would give a discription but a picture says 1000 words
i cant undo the nut as it is on radically tight,
the only time i thought i got close this happened
i have used a lot of wd40, tried using multigrips but they just cant hold it, i have also tried with a rattle gun with no success.
plz help
thanks Matt,
PostPosted: Sun Nov 06, 2011 5:53 pm
Which nut are you talking about?
If its the CV one I've had a few drum ones sieze up completely and destroy everything getting them off, however I thought I'd check the obvious: is that the wheel with the backwards thread nut?
PostPosted: Sun Nov 06, 2011 6:30 pm
yer it is the one to get the cv joint out, i thought the rear hub nut was the only one with the reverse thread? if it is a reverse thread thats awkward for me.
PostPosted: Sun Nov 06, 2011 10:21 pm
Use a ring spanner and about 3ft or 3in steel pipe same size as street sign pipe for leverage worked for me
And use sidchrome sockets they shoudnt break
PostPosted: Mon Nov 07, 2011 5:24 am
Why the use of the extension bar? That will always be a weak point undoing a hellishly tight nut.
I think I got up to a 2 meter bar once on a rusted old one.
PostPosted: Mon Nov 07, 2011 6:23 am
Drivers side nut comes off when you take the nut off anti clock wise the left is the same i think
Thats the method i used when i changed mine to get them off
PostPosted: Mon Nov 07, 2011 6:53 pm
You should always undo the nuts when the car is on the ground engine in etc.
otherwise its nah on impossible to get them off
One solution is to drill a series of small holes about 95% through one flat then use a big hammer and a cold chisel. you bugger the nuts but you can at least get them off
Ta Kiwiinwgtn
PostPosted: Mon Nov 07, 2011 7:22 pm
Online
Ta Kiwiinwgtn
I have a 150mm square lump of 12mm plate with a big hole in the middle, and 4 stud holes. And a bit of 25mm steel bar welded on it sticking out.
On car, I bolt it on then stick a brick under it, off car I grab the bar in the vice. Add a 3/4 drive socket and breaker bar + 1M of steel pipe, and the tight nut is no friggin' problem!
PostPosted: Mon Nov 07, 2011 8:14 pm
Cmon matt dont cheap out on tools :lol:
PostPosted: Mon Nov 07, 2011 8:37 pm
I dont cheap out on tools, my dad does. Nice pic btw steve
I like dr mini's idea, cause when i was turning it the wheel spun, even while i was holding it against a wall
Thanks everone for your replys
Users browsing this forum: drmini in aust and 70 guests
