how do i go about getting the driveshaft out? plz help https://www.ausmini.com/forums/viewtopic.php?f=2&t=73989 |
Author: | 123grosso [ Sun Nov 06, 2011 4:37 pm ] |
Post subject: | how do i go about getting the driveshaft out? plz help |
i would give a discription but a picture says 1000 words ![]() i cant undo the nut as it is on radically tight, the only time i thought i got close this happened ![]() i have used a lot of wd40, tried using multigrips but they just cant hold it, i have also tried with a rattle gun with no success. plz help thanks Matt, |
Author: | Harley [ Sun Nov 06, 2011 5:53 pm ] |
Which nut are you talking about? If its the CV one I've had a few drum ones sieze up completely and destroy everything getting them off, however I thought I'd check the obvious: is that the wheel with the backwards thread nut? ![]() |
Author: | 123grosso [ Sun Nov 06, 2011 6:30 pm ] |
yer it is the one to get the cv joint out, i thought the rear hub nut was the only one with the reverse thread? if it is a reverse thread thats awkward for me. |
Author: | drjbeam [ Sun Nov 06, 2011 10:21 pm ] |
Use a ring spanner and about 3ft or 3in steel pipe same size as street sign pipe for leverage worked for me And use sidchrome sockets they shoudnt break |
Author: | smac [ Mon Nov 07, 2011 5:24 am ] |
Why the use of the extension bar? That will always be a weak point undoing a hellishly tight nut. I think I got up to a 2 meter bar once on a rusted old one. |
Author: | drjbeam [ Mon Nov 07, 2011 6:23 am ] |
Drivers side nut comes off when you take the nut off anti clock wise the left is the same i think Thats the method i used when i changed mine to get them off |
Author: | kiwiinwgtn [ Mon Nov 07, 2011 6:53 pm ] |
You should always undo the nuts when the car is on the ground engine in etc. otherwise its nah on impossible to get them off One solution is to drill a series of small holes about 95% through one flat then use a big hammer and a cold chisel. you bugger the nuts but you can at least get them off Ta Kiwiinwgtn |
Author: | drmini in aust [ Mon Nov 07, 2011 7:22 pm ] |
kiwiinwgtn wrote: You should always undo the nuts when the car is on the ground engine in etc.
otherwise its nah on impossible to get them off One solution is to drill a series of small holes about 95% through one flat then use a big hammer and a cold chisel. you bugger the nuts but you can at least get them off Ta Kiwiinwgtn I have a 150mm square lump of 12mm plate with a big hole in the middle, and 4 stud holes. And a bit of 25mm steel bar welded on it sticking out. On car, I bolt it on then stick a brick under it, off car I grab the bar in the vice. Add a 3/4 drive socket and breaker bar + 1M of steel pipe, and the tight nut is no friggin' problem! |
Author: | CARTER_GT [ Mon Nov 07, 2011 8:14 pm ] |
Cmon matt dont cheap out on tools ![]() |
Author: | 123grosso [ Mon Nov 07, 2011 8:37 pm ] |
CARTER_GT wrote: Cmon matt dont cheap out on tools
![]() I dont cheap out on tools, my dad does. Nice pic btw steve I like dr mini's idea, cause when i was turning it the wheel spun, even while i was holding it against a wall Thanks everone for your replys |
