It is currently Tue Jul 22, 2025 10:58 am
PostPosted: Sun Nov 06, 2011 6:57 pm
Hi
I am wanting to work out what the internal bore size of the radius arm bushes before its reamed. eg a new one
Anyone have one lying about
Thanks
Kiwiinwgtn
PostPosted: Sun Nov 06, 2011 7:05 pm
I have a few `strange' kits here from Mini King (strange in that they have 2x bushes in and no needle bearing, so won't fit most Mini arms except 1959-61..) :?
Anyway, they are a split (ie rolled) bronze bush, and when butted up round are pretty much size for size on the shaft.
I would say after pressing in, only about .005" would need to come out with the reamer, if that.
PostPosted: Sun Nov 06, 2011 7:13 pm
I was thinking of buying this to ream out the bushes, well something simular
http://www.ebay.co.uk/itm/Morse-Expansi ... 8812690463
PostPosted: Sun Nov 06, 2011 7:35 pm
Nope you would do better with an adjustable reamer.
You can then adjust the size to fit the shaft.
I use this one-
http://www.machineryhouse.com.au/R726
Cheap but well made.
You will need to tap it then screw a guide on, to ensure alignment between the 2 bushes.
If you have a lathe you can put one end of the arm on the tailstock centre, and the reamer in the chuck.
Like this- (note for illustration only- I need a bigger centre... :lol: )
PostPosted: Sun Nov 06, 2011 8:07 pm
Thanks or the pic.
Next time you have some verniers in your hand any chance of making a sketch of the pilot part so I can get one made up
Ta
Bernard
Users browsing this forum: Andosoft and 48 guests
