Vented or unvented cap? https://www.ausmini.com/forums/viewtopic.php?f=2&t=73992 |
Author: | phillb [ Sun Nov 06, 2011 5:17 pm ] |
Post subject: | Vented or unvented cap? |
Several months ago when I changed to a standard rocker cover I was told the standard non vented cap is what I should have. But now thinking about it shouldn't I have the standard vented cap? My venting setup is pictured below. Cheers ![]() |
Author: | Morris 1100 [ Sun Nov 06, 2011 5:22 pm ] |
You should have a vented cap. |
Author: | drmini in aust [ Sun Nov 06, 2011 6:17 pm ] |
Morris 1100 wrote: You should have a vented cap.
The PCV system cama with a vented cap, but it makes SFA difference which you use really. I found this years ago. I have a vented cap on the 1360 and a non-vented on the 1412, both run a PCV from the rocker cover into the Weber manifold. No running probs, leaks or mayo with either. |
Author: | phillb [ Sun Nov 06, 2011 6:46 pm ] |
drmini in aust wrote: Morris 1100 wrote: You should have a vented cap. The PCV system cama with a vented cap, but it makes SFA difference which you use really. I found this years ago. I have a vented cap on the 1360 and a non-vented on the 1412, both run a PCV from the rocker cover into the Weber manifold. No running probs, leaks or mayo with either. I've had no problems either. The only thing I've noticed that I thought might be related is that occasionally the idle will be a little high when you first pull up then slowly drop to normal. I thought this may be as more and more of a vacuum builds up in the crankcase. |
Author: | drmini in aust [ Sun Nov 06, 2011 7:08 pm ] |
Mine both do that (with a 45 dellorto, only when hot after a good run)- so I dunno. It may be a factor, maybe not. |
