tyre pressure query. https://www.ausmini.com/forums/viewtopic.php?f=2&t=74036 |
Author: | bill.b [ Mon Nov 07, 2011 7:23 pm ] |
Post subject: | tyre pressure query. |
hey, i currently have Yokohama A048R's - 165/55 R12. i was wondering if there was a optimal tyre pressure to run in the rear tyres. Currently i have 19 PSI in the rear and they still seem quite firm. There is no weight over the back, i don't take people in the rear seat, i don't carry a spare tyre/jack around town, i have a small light weight battery. Is is absurd to run any lower? Thanks, Bill |
Author: | Lillee [ Mon Nov 07, 2011 7:26 pm ] |
Not sure about 12" wheels but I run 28psi at the front and 26psi at the back, slightly more if going for a high speed freeway run. 19 sounds way too low to me... |
Author: | bill.b [ Mon Nov 07, 2011 7:30 pm ] |
well take a look at this, these are both at 19 PSI, they don't even pillow at the bottom!? Magic. Bill ![]() ![]() |
Author: | 74snail [ Mon Nov 07, 2011 8:35 pm ] |
32 psi front and 28 psi back is what I recommend , two recommended factory pressures for 3.5x10 and 4.5x10 were 26 front 24 rear and 28 front and 26 rear , I tried on my Mini S the latter but have moved up to 32 front and 28 back and I,m not going to change anytime soon . |
Author: | Lillee [ Mon Nov 07, 2011 9:54 pm ] |
Just cause they look right don't make them right. It's because they have strong sidewalls to prevent rolling over in heavy cornering. I suggest you pump them to at least 25psi |
Author: | adamstuart [ Mon Nov 07, 2011 10:25 pm ] |
I've always run 32/30 in all my minis My mechanic runs the same on all of his mini's too! |
Author: | willy [ Mon Nov 07, 2011 10:37 pm ] |
I am also a 32/30 guy. 32/32 if I am feeling lazy ![]() |
Author: | adamstuart [ Tue Nov 08, 2011 7:15 am ] |
willy wrote: I am also a 32/30 guy.
32/32 if I am feeling racy ![]() Fixt |
Author: | drmini in aust [ Tue Nov 08, 2011 7:36 am ] |
I run 30/28 around town but that's with 10s. Works for me... ![]() |
Author: | adamstuart [ Tue Nov 08, 2011 7:41 am ] |
drmini in aust wrote: I run 30/28 around town but that's with 10s. Works for me...
![]() I always put that little bit extra, because I know it will have leaked out by the next day anyway ![]() |
Author: | bill.b [ Tue Nov 08, 2011 12:24 pm ] |
fine, i'll increase the pressure......... ![]() |
Author: | Lillee [ Tue Nov 08, 2011 2:02 pm ] |
Well it's up to you hoenstly, it's your car, your tyres and quite possibly your life if you do a corner too quickly and the sidewall collapses resulting in disaster. All I know is, there is a BIG handling difference between 25psi and 32psi in my car so I'd hate to think what it would handle like on 19psi... ![]() |
Author: | adamstuart [ Tue Nov 08, 2011 2:05 pm ] |
Lillee wrote: Well it's up to you hoenstly, it's your car, your tyres and quite possibly your life if you do a corner too quickly and the sidewall collapses resulting in disaster.
All I know is, there is a BIG handling difference between 25psi and 32psi in my car so I'd hate to think what it would handle like on 19psi... ![]() When I first bought my car, I drove it home from sutherland to blacktown on 8psi I thought it was just the no power steering.. |
Author: | goodie [ Tue Nov 08, 2011 6:03 pm ] |
Yep , same as Adam & Doc , 32/30 psi . |
