YAY Need a new Radiator
https://www.ausmini.com/forums/viewtopic.php?f=2&t=74049
Author:  brett [ Tue Nov 08, 2011 4:10 pm ]
Post subject:  YAY Need a new Radiator
Fixed my timing cover seals and refitted the radiator, and must have damaged it... Yay new Radiator time!
Any tips on refitting, Read a lot of different ideas, what have you guys found that works easy??
Author:  smac [ Tue Nov 08, 2011 5:37 pm ]
Maybe you just need to put the bottom hose on again? :wink:
Author:  brett [ Tue Nov 08, 2011 6:00 pm ]
nah, coming out the actual radiator in the middle
Author:  drmini in aust [ Tue Nov 08, 2011 7:20 pm ]
I would get yours recored. They are a better rad than most of the UK ones, including the 2 core.
Don't be tempted to buy the cheap UK 3 core, compared to an Oz 3 core it is rubbish. If you want to know why, PM me. :wink:
Author:  brett [ Tue Nov 08, 2011 9:57 pm ]
mine is a uk 2 core I bought about 13 years ago.
Author:  adios57 [ Wed Nov 09, 2011 1:03 pm ]
Doc,
Any suggestions on who to do the recore job.
The old radiator is just not keeping the car cool.
Thought about the alloy ones but heard they need an electric fan to keep cool.
Car only runs about 6 minutes before overheating.
New thermostat 82 deg, removed it put in four holes. It opened ok in being heated in a saucepan well before boiling point.
After thermostat replaced it ran for 8 minutes.
Radiator has had cleaner and reversed flished twice.
Needs recore or replace.
Author:  drmini in aust [ Wed Nov 09, 2011 1:47 pm ]
adios57 wrote:
Doc,
If the core is not leaking get it cleaned properly at a rad shop. This costs $60-$90 depending where you are.
Remove tanks
Acid dip
rod out cores
resolder tanks on
pressure test
paint.
Cheap really..
If it does need a recore they will quote you. Or take another Oz rad, and swap the cores.
