Maxi23 wrote:
There is engine oil in the weber filter since returning home with it.
Can you get oil in the filter purely from having the engine venting into atmosphere, ie, nothing is plumbed back into the manifold ?
you're saying that there is engine oil in the air filter, but the engine breathers aren't connected to the air filter in any way?
If thats the case, then for engine oil to get to the air filter it would've had to come out of the engine, swirl around under the bonnet and then get sucked into the air filter...
If that was to happen, I'd expect a very bad smell in the cabin, and oil sprayed absolutely all over the engine bay
Maxi23 wrote:
If the blow-by was related to a big end bearing, what is the best way to diagnose a dodgy big end ?
big-end bearings don't have anything to do with piston blow-by. Piston blow-by is where the air/fuel mixture goes into the engine "blowing by" the rings.
Does smoke and oil come out of the breathers if you give it a rev?
Take your oil filler cap off, put your hand over it the hole - there should be a gentle breeze. Give it a rev, there shouldn't be much more
Take it to a good mechanic and get a leak-down test done - he'll put an air fitting in the spark plug holes and there's a gauge that shows what percentage of air is leaking past the rings. I forget what is "normal"...
