Spark plugs?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=74181 |
Author: | tsb [ Thu Nov 17, 2011 7:22 am ] |
Post subject: | Spark plugs?? |
Hello All, What spark plug do you reccomend, 1098 motor?? cheers TSB |
Author: | Maxi23 [ Thu Nov 17, 2011 7:27 am ] |
I used nothing but NGK BP5ES in my 1098. |
Author: | Beanie [ Thu Nov 17, 2011 8:14 am ] |
i use BP6ES its the standard plug that rover used in the A+ motors .. 998 and 1275 Beanie |
Author: | drmini in aust [ Thu Nov 17, 2011 10:47 am ] |
BP (or was it Bosch, I can't remember) on their website recommend going 1 heat range hotter than original, for general commuting running unleaded fuel. So, BP6ES>BP5ES. Unless you are thrashing it I'd say the 5s better suit a 1098 anyway. I'm using 5s in my 114HP 1412 roady, no problemo. ![]() [edit] these are BPR5EY, are a little longer projection than ES but the same heat range. |
Author: | Boostedmini [ Thu Nov 17, 2011 12:29 pm ] |
I'm with the Doc, I use BP5RES in my 190hp turbo 1293 motor. they worked best on GR's dyno so thats all i use on the road. big boost and track days i also have used B8EGV but they are a little too cold i think. Grant |
Author: | pristic [ Thu Nov 17, 2011 12:51 pm ] |
I used to use BPR5ES also however since winding up boost etc ive gone to BPR6ES I would stick to the 5's for a normal and mild 1098 and 998 Pete |
Author: | TK [ Thu Nov 17, 2011 12:58 pm ] |
NGK, BPR6EIX. |
Author: | pristic [ Thu Nov 17, 2011 1:20 pm ] |
TK wrote: NGK, BPR6EIX.
Why would you use Iridiums in a classic Mini?? Just a waste of money imho (in fact, I even ran normal plugs in my XR8) just change them more often. Each to their own but I dont think there is any advantage (even the fact they dont need to be changed as often) Cheers, Peter |
Author: | TK [ Thu Nov 17, 2011 1:23 pm ] |
I found much easier starting. |
Author: | pristic [ Thu Nov 17, 2011 1:30 pm ] |
TK wrote: I found much easier starting.
Really? Wow... you tried both the iridium in a 6 and the normal 6ES ? And the iridium helps with starting? Thats pretty cool. Are you still running a dizzy or gone electronic? Cheers, Pete |
Author: | TK [ Thu Nov 17, 2011 6:20 pm ] |
I'm using electronic ignition. |
Author: | hutto [ Sat Jan 07, 2012 11:56 am ] |
Champion- N9YC Bosch- W8DC or W6DC NGK- BP6ES |
