It is currently Mon Jul 21, 2025 9:08 pm
PostPosted: Thu Nov 24, 2011 9:40 am
Hey
I asked Minisparesonline this question, and would like a little more info please.
Need to buy some coil overs for a project im building and need standard height 387mm open with 121mm stroke coil overs (ill order springs later when rates are worked out)
Having trouble dealing with Protech so I emailed and asked minisparesonline about the difference in Gaz and Protech, price, not much difference...
Protech $362.60 (fronts with brackets and springs - both I dont need)
GAZ $307.42 (same as above)
"We only do the one height for the coilovers, as the brackets supplied are what make they suitable for lowering. Both are a good shock but the difference is that the Protech is alloy and the Gaz is steel."
Do not want to order until I know the length. has anyone bought coil overs from them and know the lengths? I also need to know the eyelet ID size.
Users browsing this forum: fuzzy-hair-man and 70 guests
