Recommend a place to stroke a 1275LS crank? https://www.ausmini.com/forums/viewtopic.php?f=2&t=7430 |
Author: | moke007 [ Sun May 22, 2005 12:17 pm ] |
Post subject: | Recommend a place to stroke a 1275LS crank? |
Hi All, I have a 1275LS crank that I am going to get stroked as finances permit. Can any one recommend a place in either Newcastle or Sydney. Also how many $$$$ do you think I will be looking at? I already have the S rods available and will but some 73.0mm Hypertec pistons. cheers Jim |
Author: | 9YaTaH [ Sun May 22, 2005 12:44 pm ] |
Post subject: | Re: Recommend a place to stroke a 1275LS crank? |
moke007 wrote: Hi All,
I have a 1275LS crank that I am going to get stroked as finances permit. Can any one recommend a place in either Newcastle or Sydney. Also how many $$$$ do you think I will be looking at? I already have the S rods available and will but some 73.0mm Hypertec pistons. cheers Jim Recommend a place to stroke a 1275LS crank?...well I don't really like to talk about this sort of thing in public...but OK.....the webs are a little rough so I steer clear of them, the nose is too purposeful and there are some sharp edges there....so the journals....oh yes...the journals...thats the place to stroke a 1275 crank:oops: Oh you meant machining work....I have only heard mention of one place up your way and I suggest the Novacastrians on Ausmini should talk about that....MiniMonaro etc How hard is it for you to get down to Sydney?? lots of possibilities there.. |
Author: | drmini in aust [ Sun May 22, 2005 2:25 pm ] |
St George Crankshafts (Spiro Georgiou) 2/9 Bearing Rd Seven Hills 2147 ph (02) 9674 1201 mobile 0417 276 030. He did mine recently. He charges around $240 to stroke it, with all journals ground. ![]() ![]() ![]() Should ring like a bell when you do this. If not, it's probably a dud.. |
Author: | moke007 [ Sun May 22, 2005 4:37 pm ] |
9YaTaH wrote: Recommend a place to stroke a 1275LS crank?...well I don't really like to talk about this sort of thing in public...but OK.....the webs are a little rough so I steer clear of them, the nose is too purposeful and there are some sharp edges there....so the journals....oh yes...the journals...thats the place to stroke a 1275 crank:oops: ![]() Quote: etc
How hard is it for you to get down to Sydney?? lots of possibilities there.. I work in lovely downtown Castle Hill so Sydney is not a problem. |
Author: | moke007 [ Sun May 22, 2005 4:42 pm ] |
drmini in aust wrote: St George Crankshafts (Spiro Georgiou)
2/9 Bearing Rd Seven Hills 2147 ph (02) 9674 1201 mobile 0417 276 030. He did mine recently. He charges around $240 to stroke it, with all journals ground. ![]() That sounds good Dr Mini, Seven Hills is nice and easy as well. Does the $240 include getting it tuffrited (spell?) I have heard that getting it hardened is where it can all go wrong.... Thanks for the info Jim |
Author: | drmini in aust [ Sun May 22, 2005 4:59 pm ] |
No it doesn't include tuftriding, or nitriding, which is more common now.. I investigated this a while back, and like 99% of Graham Russell's race motor customers, I'm now leaving mine as is.. it's 84.3mm stroke with std/std bearing sizes. (I saved a bit of $$ as the std mains were mint). Spiro grinds all GR's cranks, and does nice work. I've seen a stroker 12G1505 crank that had been `nitrided'- when it all went pear shaped on the track, it wore the pins just like a standard 1100S crank would. ![]() <edit> Quoted from www.matter.org.uk - "To get a hardening effect on nitriding the steel must contain strong nitride forming elements such as Al, Cr and / or V." Note that EN16 steel used in these cranks has no Al, or V, or Cr. It's a Manganese Moly steel- C 0.32-0.4%, Si 0.1-0.35%, Mn 1.3-1.7%, S 0.04% max, P 0.35% max, Mo 0.22-0.32% Anyhow why not ring Spiro and discuss it, or go see him... ![]() |
Author: | moke007 [ Sun May 22, 2005 7:06 pm ] |
Thanks for all the info Dr Mini, I will give Spiro a call and have a chat. It sounds like they do very good work which is reassuring (sometimes hard to find) thanks again, Jim |
