May have found a Moke. . . But . . . https://www.ausmini.com/forums/viewtopic.php?f=2&t=7432 |
Page 1 of 2 |
Author: | kazjim [ Sun May 22, 2005 4:02 pm ] |
Post subject: | May have found a Moke. . . But . . . |
ok all, the project may have just recieved its first "Kickoff" A Guy came around yesterday looking for a fuel pump for his moke, ... we got to chatting, and it turns out he has a second moke that he doesnt need... No canopy, no engine (Perfect ![]() One of the major bits missing is the compliance plate AND the radiator shroud (missing chassis number) Is this insurmountable ? Being replacable panels, can i just get a new radiator shroud panel from M&M world and have it stamped with the number from a plate that i source from elsewhere ? Anyone ? - Its for a good cause.... RXMOKE needs a body-shell..... ![]() J |
Author: | gafmo [ Sun May 22, 2005 4:10 pm ] |
I'm crossing my Fingers James ![]() |
Author: | simon k [ Sun May 22, 2005 6:13 pm ] |
pm sent |
Author: | aaron [ Sun May 22, 2005 6:28 pm ] |
for 200 it is worth picking up. even if it ends up as a motorkhana special. Hmmm Don't you have a new turbo going on the mini..... spare turbo + Moke shell..... Thoughts have to be going thru your head. It just has to be done. Cheers Aaron |
Author: | kazjim [ Sun May 22, 2005 7:28 pm ] |
"RXMOKE" as in RX-7 Moke ... As in 12A Rotary in a Moke As in 12A Rotary Front Wheel Drive in a Moke Pffft turbo ..... But seriously, if i can get it in and working, then there is a potential for people all over the world to stop f**king around and actually start putting Rotaries in minis ..... seems to be the second question and mini modifier asks .... ![]() Well, its begging to be done, and I'm a stubborn enough bastard to do it....Turbo'd a 998 against everyone better judgement didnt I ? he he he J |
Author: | 9YaTaH [ Sun May 22, 2005 7:46 pm ] |
Post subject: | UmmHH! |
kazjim wrote: "RXMOKE"
as in RX-7 Moke ... As in 12A Rotary in a Moke As in 12A Rotary Front Wheel Drive in a Moke Pffft turbo ..... But seriously, if i can get it in and working, then there is a potential for people all over the world to stop f**king around and actually start putting Rotaries in minis ..... seems to be the second question and mini modifier asks .... ![]() Well, its begging to be done, and I'm a stubborn enough bastard to do it....Turbo'd a 998 against everyone better judgement didnt I ? he he he J Its already been done...search on Paul Gulson ![]() ![]() |
Author: | kazjim [ Sun May 22, 2005 7:53 pm ] |
Front wheel Drive, Mazda Rotary in a Moke/Mini ? First I've heard of it...the only other rota mini was the chopped roof one that was rear wheel drive.... also a van i think.... More details ? J |
Author: | drmini in aust [ Sun May 22, 2005 7:58 pm ] |
Wasn't someone on the Gold Coast? putting single rotors into Minis a little while back? |
Author: | 9YaTaH [ Sun May 22, 2005 8:10 pm ] |
Post subject: | Re: UmmHH! |
9YaTaH wrote: kazjim wrote: "RXMOKE" as in RX-7 Moke ... As in 12A Rotary in a Moke As in 12A Rotary Front Wheel Drive in a Moke Pffft turbo ..... But seriously, if i can get it in and working, then there is a potential for people all over the world to stop f**king around and actually start putting Rotaries in minis ..... seems to be the second question and mini modifier asks .... ![]() Well, its begging to be done, and I'm a stubborn enough bastard to do it....Turbo'd a 998 against everyone better judgement didnt I ? he he he J Its already been done...search on Paul Gulson ![]() ![]() Paul Gulson used to race a rotary powered Sports Sedan...he now up around Brisvegas.... |
Author: | Morris 1100 [ Sun May 22, 2005 8:26 pm ] |
The rotary powered Sportsedan had the engine beside the driver with a Hewland gearbox on the front of the engine. Not realy suitable for a road car and it was not legal as a sportsedan! |
Author: | moemoke [ Sun May 22, 2005 8:47 pm ] |
have always wanted to but a rota in my moke (had rx2's & rx7 for about 20 years) the best thing i rekon about moke is handling, steering ,suspension, plus other things of corse. so i'd make mine rwd (mid mount rota behind front seats) with a modified front subframe in the rear that way steering and suspension stays same. put large fuel tank and radiator in front where motor was to keep things balanced. gearbox would be subaru, maybe auto so linkage is easy. gearbox would almost be hidden from rear. i rekon this would be the ultimate sleeper! if it could be done. and mine would be called REMOKE. did see a fwd rotary mini sports sedan years ago at morwell hillclimb. |
Author: | bnicho [ Sun May 22, 2005 8:52 pm ] |
Im sure you could, say, er, miraculously locate (cough, cough) your Moke's missing compliance plate. Then simply stamp the number from the complance plate on the body in the vicinity of the radiator. ![]() |
Author: | Chris [ Sun May 22, 2005 8:53 pm ] |
Post subject: | Re: May have found a Moke. . . But . . . |
kazjim wrote: Is this insurmountable ? Being replacable panels, can i just get a new radiator shroud panel from M&M world and have it stamped with the number from a plate that i source from elsewhere ? (may have to talk to a certain Novacastrian about some pre-72 compliance plates. . ) Anyone ? - Its for a good cause.... RXMOKE needs a body-shell..... ![]() J It is technically illegal as you are rebirthing a car. No wrecker if they value their license is going to sell you a compliance plate or body number. having said that it is done quite regularly and as you are not thieving and not profiting what is the harm? I think you will have to find private sources for your compliance plate. Writing about things like this on forums is best avoided. PMs are the go. |
Author: | J_A_M [ Mon May 23, 2005 9:18 am ] |
exactly what he said ^^^^^ |
Author: | blumin [ Mon May 23, 2005 9:55 pm ] |
Post subject: | Moke |
PM sent Blumin |
