It is currently Mon Aug 04, 2025 1:08 pm
 Post subject: Differential questions
PostPosted: Wed Nov 30, 2011 3:38 pm
In the process of stripping and renewing subframe bits and pieces.
Im about to pull off the hubs, cvs etc.
On the end of the cv I currently have whats in the top of this pic. Rubber coupling?
Whats the best driveshaft to go with?
I have heard of/seen pot joints, hardy spicer etc.
I'm pretty sure I have 2 of the big ball bearing type that came with the car. Pot joints??
Also, I plan of going lsd when I build my gearbox.
What type of driveshaft/coupling is best for lsd purposes?
Just trying to get my head around driveshafts/diffs amongst other things!
PostPosted: Wed Nov 30, 2011 4:05 pm
yeah well , imo if you`1re going for the Quaife diff then Pottys are the go , concidering that it "Seems" you already have that set-up
PostPosted: Wed Nov 30, 2011 4:49 pm
Does using an a+ box pose any other problems?
PostPosted: Wed Nov 30, 2011 4:57 pm
no, not that i can see or think of, i reckon they~re pretty good actually
