Caliper retaining bolt spring washer https://www.ausmini.com/forums/viewtopic.php?f=2&t=74349 |
Author: | harry33 [ Sat Nov 26, 2011 9:11 pm ] |
Post subject: | Caliper retaining bolt spring washer |
Hi there, A while ago I bought a 7.5" Cooper S disc brake conversion kit and fitted it to my car, but I'm not sure whether I should use spring washers or loctite or something on the bolts which hold the calipers to the hubs.. Nothing was provided with the kit, but I would have thought these bolts were sufficiently important to warrant the use of some kind of locking mechanism.. Should I use loctite or fit spring washers, or is there some reason I haven't thought of which should stop these bolts coming undone anyway? Cheers, Harry |
Author: | drmini in aust [ Sat Nov 26, 2011 9:34 pm ] |
Spring washers on the caliper bolts were original, and work fine- try and find some decent square section ones though (not the chinese bent bit of wire version) |
Author: | GT mowog [ Sun Nov 27, 2011 4:36 am ] |
The original spring washers were a Medium Grade. These days we only seem to be supplied with Light Grade ![]() |
