It is currently Sat Aug 02, 2025 2:04 pm
PostPosted: Tue Nov 29, 2011 10:03 am
i have a rover servo on my mk1 mini
fitting the minispares kit with braided lines to make it moveable when lifting the engine out it has a metric fittings to suit the later car, I have to get a set wtih unf banjo bolt ends to suit a mk1 setup.
would any one have any idea what i need i know it is UNF thats for sure but not sure what size. 3/8? Do I need to know any other info to get it fit the banjo bolt?
where could i get something like that local?
PostPosted: Tue Nov 29, 2011 10:17 am
3/8in is correct, whats got me frazzled is where you mention late cars being metric.
I've not come across that, the late parts I have are all imperial like the 60s stuff.
The late booster should have UNF fittings like normal, what do you have thats metric?
PostPosted: Tue Nov 29, 2011 10:23 am
Lol to be honest Harley I did not check I know some of the later boosters Or later rovers are another thread the did change over.
I'm. Ot sure if I have a later ro er booster or a early one.
I guess time to check.
PostPosted: Tue Nov 29, 2011 11:57 am
Yep not the same size. I'm not using the rover bias valve either.
I using the moke one.
PostPosted: Tue Nov 29, 2011 12:16 pm
Moke huh? I don't do Moke.
Sorry, on your own.
:lol:
PostPosted: Tue Nov 29, 2011 3:46 pm
Sorry, on your own.
:lol:
Yeh that is in the rear of the subframe anyways.
The rover booster is metric thread our cars for the brake lines have a 3/4 unf 24 thread.
So all sorted was not very hard in the end.
