Help required now if possible. RE: Oil filter https://www.ausmini.com/forums/viewtopic.php?f=2&t=7438 |
Author: | Harley [ Sun May 22, 2005 5:48 pm ] |
Post subject: | Help required now if possible. RE: Oil filter |
Hey, I'm in the middle of changing my oil filter. The one that came off is different to what I have, and according to the how ever many manual I have, there is supposed to be a spring forcing the filter up to the engine away from the housing it is in. Mine doesn't have a spring, and it appears the original filter might not have been sealing properly if there is supposed to be one. Is a spring required? |
Author: | Morris 1100 [ Sun May 22, 2005 6:20 pm ] |
Yes, it should have a spring. |
Author: | simon k [ Sun May 22, 2005 6:21 pm ] |
yeah, there should be a plate at the bottom of the filter housing, with a big spring under it - the spring forces the filter up to the top pof the housing - if it wasn't there before, then the filter wasn't filtering, the oil would have gone over the top of it and back into the motor go get a spring - if you can't find a proper one, find one about 2 inches long and fairly strong |
Author: | Harley [ Sun May 22, 2005 6:23 pm ] |
Thanks guys. I could tell it wasn't working by the amount of steel stuck on the drain plug. So much for a quck job. |
Author: | aaron [ Sun May 22, 2005 6:25 pm ] |
Goto Ebay uk and get the spin on oil filter type one. Much better and cheap mod for the $20 it'll cost you to get it here. I know this don't help you now but worth it the long run. Cheers Aaron |
Author: | Harley [ Sun May 22, 2005 6:30 pm ] |
Can you buy them here? |
Author: | aaron [ Sun May 22, 2005 6:34 pm ] |
you can but they cost more, if you need one in a rush, i am sure someone may come to the party with oe you can buy. sorry i havn't got a spare at the moment. Also the filter will cost ya $5 odd bucks rather than the other ones which if i recall cost somewhat more. Plus changing them takes 2 minutes rather than an hour for the old type(yes a small lie, but you get my point). Cheers Aaron |
Author: | Harley [ Sun May 22, 2005 6:45 pm ] |
I was going for more than an hour the sarvo, and haven't fiished yet! Don't know about most of you people, but I have to remove the grill to change my filter. |
Author: | 68matic [ Sun May 22, 2005 7:22 pm ] |
Harles, you must have all of the parts that are shown, like the exploded views of the filter i realised after about oil 3 changes i was missing the seal plate which sits on the end of the filter i mustve thrown it out coz it was stuck to the filter so dont throw yours out, theyre $16 to replace |
Author: | Harley [ Sun May 22, 2005 7:25 pm ] |
I've not thrown anything out yet, I don't do it until everything is working properly. |
Author: | 68matic [ Sun May 22, 2005 7:32 pm ] |
when everything is covered in oil and the seal plate sticks on the end of a hot oil filter you just wanna play hot potato with, you dont really notice it ![]() |
Author: | Morris 1100 [ Sun May 22, 2005 8:04 pm ] |
Not all filters have a plate on the bottom of the filter. If it takes a Ryco R2200P filter it does not have a plate. Look at type D and E in the photo below. They are the Australian made filter case that take the R2200P filter. ![]() Thanks to ImageShack for Free Image Hosting |
Author: | drmini in aust [ Sun May 22, 2005 8:30 pm ] |
Morris 1100 wrote: Not all filters have a plate on the bottom of the filter. If it takes a Ryco R2200P filter it does not have a plate.
Look at type D and E in the photo below. They are the Australian made filter case that take the R2200P filter. ![]() Thanks to ImageShack for Free Image Hosting They all had a plate, but.. Early filters (and S) had a separate plate, the Deluxe and later (with the filter switch thingy in the housing) took the filter with the integral plate. S filter originally was a felt one, God knows why.. Can't remember the numbers of all of 'em now, I'm a spin-on convert.. ![]() |
