It is currently Sun Jul 20, 2025 4:11 am
 Post subject: Spot Weld Drills
PostPosted: Sun Dec 04, 2011 2:38 pm
Afternoon All,
Just looking for some recommendations for a bit to drill out the spot welds for my various repairs :)
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
PostPosted: Sun Dec 04, 2011 2:52 pm
I got mine from a seller on eBay. Haven't used them yet so can't report how good they are. About $12 each from memory.
Dicko.
PostPosted: Sun Dec 04, 2011 3:06 pm
I got one like a mini hole-saw with a spring-loaded centre. It works OK, but it's very easy to chip a tooth off which makes it real hard to control. It likes to grab and goes off-centre, you really need a small hole rather then a centre punch to keep it on centre.
Lately I have just been using a drill bit, about 8mm, sharpened with a really shallow point angle so it doesn't penetrate through the second panel. Heaps quicker and easier and lasts much longer. Then you just re-sharpen when you need to. Cheaper too.
Madmorrie
PostPosted: Sun Dec 04, 2011 4:47 pm
Thanks Guys,
I've had trouble deciding between the two.
I might have a crack with the shallow drillbit type.
Ian
PostPosted: Sun Dec 04, 2011 4:52 pm
Madmorrie
I normally sharpen one up also, similar to a sheet metal drill. You can also have a range of drill sizes then too.
If you know a toolmaker or someone good at sharpening drills maybe they can sharpen for you?
Mini's I grew up with
Slot car couch
PostPosted: Mon Dec 05, 2011 8:38 pm
IAN.
There are several methods as aove, which are excelent if you need to save the panel.
If your going to replace the panel with new, then I find its fairly easy to grab a small grinder, and with the tip of the wheel, I grind into the "spot". The top sheet (around the spot) sits up about 1/2 mm and this weakens it enough to rock n roll off. As I said, its quick but destroys the old panel.
Alex.
