It is currently Tue Aug 05, 2025 9:43 am
 Post subject: Engine removal questions
PostPosted: Wed Nov 30, 2011 9:59 pm
Hi all,
I'm planning to remove my Mini's engine soon, and I have a few questions..
I'm going to make up a lifting bracket like the one in the How To section (but I will make a hole for the D shackle rather than welding it on), but I'm not sure what thickness of angle iron to get. I was thinking 5mm, but that won't leave all that many threads on the head studs (especially when the head washers are on there too, and I would have thought it is a good idea to use these), so what thickness would you guys suggest?
I also tried to remove a few of the head nuts (the middle three at the front), but with
two of them the studs started to come out of the block before the nuts turned on the studs :? Any suggestions as to what I might do about this?
Finally, I remembered after loosening the above three studs/nuts that the head nuts are supposed to be tightened and loosened in a particular order to avoid warping the head.. Do you think loosening the middle three nuts at the front while leaving the rest tight will have caused me problems?
Harry
PostPosted: Wed Nov 30, 2011 10:05 pm
5mm will be fine, especially if you`re using 3x head nuts/studs
& don`t worry if the studs loosen a bit, big deal, rip them out, fit your bracket & bolt them back in
it`ll be fine to lift the engine out
i only use the one center bolt/nut & that`s all we`ve ever done, 40-plus years of pulling mini engines out & not once had a problem using the one center bolt/nut,,, so using 3x of them will be sweet as, no-problemo
PostPosted: Thu Dec 01, 2011 6:51 am
Online
Leave the headwashers off when fitting the lift bracket.
I cut away the bracket to use 2 studs, and leave the middle stud and nut tight.
If a stud comes out, just put it in a vice and take the nut off, then lock 2 nuts onto it and screw back in.
PostPosted: Thu Dec 01, 2011 7:39 am
The brackets I've made have been 3mm and had no problems
David L
PostPosted: Thu Dec 01, 2011 7:56 am
My bracket is 6mm but had the holes slightly countersunk where the nuts will screw down and fit into the plate and I don't fit washers
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Dec 01, 2011 9:10 am
Ok, I will probably go with 5mm then.
Thanks for the help,
Harry
Users browsing this forum: Barkfast, drmini in aust and 92 guests
