sub woofers in minis https://www.ausmini.com/forums/viewtopic.php?f=2&t=74428 |
Author: | Kermit [ Wed Nov 30, 2011 8:51 pm ] |
Post subject: | sub woofers in minis |
As im getting my mini ready to be put on the road, one of the things i want to do is add a subwoofer but don't want to take up all the room in the world as the boot is small enough as it is. So I am just curious as to who has installed suttle subs and different ways to install them just to get some ideas of how to do my own ![]() Thanks to all that reply in advance d:o) |
Author: | Harley [ Wed Nov 30, 2011 9:03 pm ] |
If you don't want to take up much space I'd look at one of them 8" active subs with inbuilt amp to under the passengers seat. It'll sound fine in a mini. Personally though, I have four 8" JBL subs under the back seat, running at 1000wrms. Has a little more kick at that power level. ![]() |
Author: | Kermit [ Wed Nov 30, 2011 9:28 pm ] |
yeah i was looking at these new pioneer 6x9 fully independant and inclosed subwoofers but they are like a rectangle shaped so a little harder to fit and im worried about, if it put it under the seat that it may get damaged? maybe under the back seat but im not sure if it will sit snug under there or not :S |
Author: | Harley [ Wed Nov 30, 2011 9:36 pm ] |
You'd fit one of them under the drivers seat up against the crossmember, its nearly taller than the sub! |
Author: | Kermit [ Wed Nov 30, 2011 9:41 pm ] |
yeah but i like simitry in my car so i'd have to do one on each side lol. apparently the power out of one of these is pretty insain for a big car so it should sound pretty good in the mini. I was thinking about mounting a single 10" sub in the boot but then it would take up alot of room so i think under the seat is the way to go? |
Author: | Tombo [ Wed Nov 30, 2011 10:25 pm ] |
It's a bit of work, but you could mold a fibreglass back for a sub enclosure to fit over the right guard in the boot and attach an mdf or ply front to mount the speaker, a 10" needs about 30L volume for an enclosed box so it will only be slightly bigger than a fuel tank. Otherwise, do what Harley did, that would have some real punch ![]() |
Author: | Kermit [ Wed Nov 30, 2011 10:43 pm ] |
yeah well that was an option i was looking at. was actually gonna get a tank to go off and to use as a reference so that is an option. I've had alot of trouble finding 8" subs in the bast so not sure if that's a road i will go down yet. wait and see what happens i guess. ill work it out ![]() |
Author: | Bubbacluby [ Wed Nov 30, 2011 10:53 pm ] |
Harley wrote: If you don't want to take up much space I'd look at one of them 8" active subs with inbuilt amp to under the passengers seat. It'll sound fine in a mini. Personally though, I have four 8" JBL subs under the back seat, running at 1000wrms. Has a little more kick at that power level. ![]() Personally i love this and intend to make one: http://www.theminiforum.co.uk/forums/in ... 4097&st=15 Tombo wrote: It's a bit of work, but you could mold a fibreglass back for a sub enclosure to fit over the right guard in the boot and attach an mdf or ply front to mount the speaker, a 10" needs about 30L volume for an enclosed box so it will only be slightly bigger than a fuel tank.
Otherwise, do what Harley did, that would have some real punch ![]() Just like this: http://www.theminiforum.co.uk/forums/in ... opic=93783 |
Author: | Kermit [ Wed Nov 30, 2011 11:04 pm ] |
this could be a good idea, hmm I'm gonna have to do some more research and see what i can find ![]() |
Author: | Gordo [ Thu Dec 01, 2011 6:59 am ] |
There was a sub woofer thread in the car audio section a while back. I forget what brand of sub it was but they would be a great fit under a seat... Like others have said it's a sub with amp and from memory it wasn't too much bigger than an A4 piece of paper but obviously thicker Edit... Focal BUS 20 8" under-seat subwoofer with amplifier Nominal power 60 W Maximum power 120 W Frequency response 50Hz - 400Hz Subwoofer 20cm (8") Aluminum active box External remote control Supplied HxLxW 76x348x242 mm http://www.focalaustralia.com.au/access_1.html#bus25 |
Author: | Kermit [ Thu Dec 01, 2011 8:58 am ] |
yeah pioneer make one very similar to that and they're from memory even more compact but pack a real punch. I have a ll pioneer gear in my mini so i will try to stick with the same brand if i can but ill see what i can find ![]() |
Author: | raisto2 [ Thu Dec 01, 2011 9:44 am ] |
Gordo wrote: There was a sub woofer thread in the car audio section a while back. I forget what brand of sub it was but they would be a great fit under a seat...
Like others have said it's a sub with amp and from memory it wasn't too much bigger than an A4 piece of paper but obviously thicker Edit... Focal BUS 20 8" under-seat subwoofer with amplifier Nominal power 60 W Maximum power 120 W Frequency response 50Hz - 400Hz Subwoofer 20cm (8") Aluminum active box External remote control Supplied HxLxW 76x348x242 mm http://www.focalaustralia.com.au/access_1.html#bus25 i've got that in my telstar and it's rather good for it's size, i bought it to fit under my seat and it would have if mazda/ford hadn't left a random redundant bracket in the middle under my seat ![]() |
Author: | Kermit [ Thu Dec 01, 2011 10:39 am ] |
yeah im thinking about giving the under the back seat mounted ones a go first and see how that turns out i think. if not then i can always get the under the seat ones instead |
