Driveshaft end removal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=74454
Author:  Kurross [ Fri Dec 02, 2011 7:11 pm ]
Post subject:  Driveshaft end removal
Good evening all,
Looking for some instructions/ tips/advice on how to remove the inner end of the driveshaft.
I have purchased new inner cvs, but i'm buggered if I know where to start to get the old end bit off??
I have checked both the workshop manuals I have but cant seem to find it.
hope you can help.
Mark
Author:  sitnlo62 [ Fri Dec 02, 2011 8:17 pm ]
The inner pot joint end is held on with the same method as the outer cv,
Hold the shaft in a vice with some soft jaws and knock it off with a hammer and a drift.
Dave
PS, keep an eye out for the small section "O" ring on the shaft and be sure to refit.......
Author:  Kurross [ Fri Dec 02, 2011 10:05 pm ]
Thanks for the response!
Righto, so i should be able to knock it off then, btw what is a drift? (is this something to grip the end bit, so it can be knocked off?)
Author:  sitnlo62 [ Fri Dec 02, 2011 10:55 pm ]
A Drift? Good Question.
In this case you could use anything from a piece of Hard wood, Aluminium, Brass, Copper or Mild Steel to hold against the obrect to be removed and then stike it with the hammer,
This allows you to more accurately position the force required on the object to be removed.
From Dictionary A. A tool for ramming or driving something down
B: A tapered steel pin for enlarging and aligning holes.
Dave
Author:  Kurross [ Sat Dec 03, 2011 6:01 am ]
ok, that makes sense. thanks again.
i'll give it a go
i'll give it a go
