Mini spit plans/pics https://www.ausmini.com/forums/viewtopic.php?f=2&t=74555 |
Author: | min16i [ Fri Dec 09, 2011 6:28 pm ] |
Post subject: | Mini spit plans/pics |
Evening All, Starting to get all a bit serious about doing something with the old 61. Does anyone out ther in Ausmini land have plans/dimensions/pics of Mini spits? Going to need to mount mine up for some body work soon and so will need to build one. Ian |
Author: | VulcanBB18 [ Fri Dec 09, 2011 7:18 pm ] |
Search - either here or with google gets easy results ![]() Here's one design : http://minimikebc.tripod.com/rotiss.html Plenty around, seen the "two engine stands" type here a few times ![]() cheers, |
Author: | Kennomini [ Fri Dec 09, 2011 8:05 pm ] |
Check out this link of mine; http://s182.photobucket.com/albums/x314 ... otisserie/ What model mini is the spit for? Later model clubmans will have different mounting options. The difference in mounts will be seen in my photobucket pics ![]() |
Author: | min16i [ Fri Dec 09, 2011 8:32 pm ] |
Thanks Guys, Lovin the pics Kennomini. Mines a 1961 so early. What sort of height is yours? Ian |
Author: | Kennomini [ Fri Dec 09, 2011 8:50 pm ] |
Can't remember. If you mount the pole first then measure off that to the corners of the shell and then add a bit more and it should work out. |
