Who sells these in Australia? https://www.ausmini.com/forums/viewtopic.php?f=2&t=74611 |
Page 1 of 2 |
Author: | Hanra [ Tue Dec 13, 2011 12:44 pm ] |
Post subject: | Who sells these in Australia? |
http://www.minispares.com/Product.aspx? ... 540&title= They are used to hold the rear boot lid badges on. |
Author: | TheMiniMan [ Tue Dec 13, 2011 1:05 pm ] |
original p/n JLM270 description--> "Snib" i`m pretty sure i have a pile of em here i`ll check it out before i say anything else ![]() Matt |
Author: | bnicho [ Tue Dec 13, 2011 1:16 pm ] |
Commonly called "Mouse Condoms". ![]() |
Author: | Morris 1100 [ Tue Dec 13, 2011 2:37 pm ] |
I discovered the other day that they come in two sizes. The normal ones were too big for the thin pins on the Automatic badge for the 1100. ![]() |
Author: | Hanra [ Tue Dec 13, 2011 3:12 pm ] |
Hmmm. Mouse Condoms....Hmmmm.... Im hoping that hey will be suitable for the mounting of the T O R A N A badge across my nose cone. I reckon the will be.... but just cant remember how big the I/D and O/D are....... Hey Matt, if you do have some, reckon you can stick a pair of verniers on em and get some sizes mate? |
Author: | Panthersteve [ Tue Dec 13, 2011 3:14 pm ] |
Ken Nelson at Mini Automotive has had them when I needed them. |
Author: | Morris 1100 [ Tue Dec 13, 2011 4:01 pm ] |
The proper Holden ones are little metal ones that chip the paint and cause rust. I might have a couple of them somewhere but I wouldn't have enough for a whole front panel. |
Author: | Hanra [ Tue Dec 13, 2011 4:39 pm ] |
Hahahahaha really?? Hmmmm... I think its a good idea to use the plastic condoms then instead? |
Author: | Morris 1100 [ Tue Dec 13, 2011 4:45 pm ] |
Hanra wrote: Hahahahaha really?? Hmmmm... I think its a good idea to use the plastic condoms then instead?
Really! With some Holdens in coastal areas you may see a thin trail of oxide/rust running down the paint below the badge. The metal clip has a bit of a lip that stops it pulling out but it can and will chip the paint. The plastic ones are much better as long as they are the right size for the pins and holes. |
Author: | GT mowog [ Tue Dec 13, 2011 5:39 pm ] |
Post subject: | Re: Who sells these in Australia? |
Hanra wrote: http://www.minispares.com/Product.aspx?ty=pb&pid=35540&title=
They are used to hold the rear boot lid badges on. Hi Hanra, Try Spectrum Rubber. http://www.spectrumrubber.com.au/ |
Author: | slacko [ Tue Dec 13, 2011 5:59 pm ] |
John at Miniking has them in stock to I am pretty sure ring him 0246481233 |
Author: | AJ [ Tue Dec 13, 2011 6:40 pm ] |
Lindsay Siebler sells them try here : http://www.minis.com.au/minis/catalog/i ... ef8c97f2d5 |
Author: | dodge [ Tue Dec 13, 2011 7:31 pm ] |
use these http://www.ebay.com.au/itm/Ford-Falcon- ... 43a9ef93be ford speed nuts |
Author: | rathcoole [ Tue Dec 13, 2011 7:55 pm ] |
Hey Hanra, they should be - PANEL HOLE; 3/16" / 4.7MM AND PIN DIAMETER 1/8" / 3.2MM. if they are not the right size, I have some slightly smaller and slightly larger ones that might fit. cheers Kev |
Author: | TheMiniMan [ Tue Dec 13, 2011 8:10 pm ] |
yeah sorry i havn`t checked, i`m a lazy bugga sometimes & my excuse is that i`m going into hospital for a heart opperation tomorow & it would be far too stressing for me to walk down to the shed, open a draw & check to see if i carry mouse condoms... it`s just too stressing, far too much for me to take, i`m too frail atm leave me alone , stopp bullying me Mwaaahhh haa haaa i want my mummy !!!!!!!!!!! |
