It is currently Tue Aug 19, 2025 12:03 am
PostPosted: Fri Dec 16, 2011 9:02 am
Ey guy, is there a way to remove the strips that go around the top of the door without damaging it? I have attempted taking one off one of my damaged doors and it didnt go well.
Thanks Matt.
PostPosted: Fri Dec 16, 2011 10:55 am
Hit the top lip of the mould from the inside using a rubber mallet you can also use a block of wood and a hammer
1970 Mk 2 Cooper S
PostPosted: Fri Dec 16, 2011 3:45 pm
They are a pain to get off, you'll probably scratch some paint on the door hoop but just be firm with them and work your way around.
PostPosted: Fri Dec 16, 2011 3:49 pm
They are a pain to get back on too, without scratching the paint off. The only reason I took one off during the rebuild last year was my spare (original) LH door going back on was missing one from last time! :lol:
PostPosted: Fri Dec 16, 2011 4:22 pm
I only need to do one door because i am doing a colour change with it, the other door is already yellow so i can mask that bit up.
How did they put it on at the factory?
PostPosted: Fri Dec 16, 2011 6:40 pm
trick to get back on it to use a bit of grease, press bottom over door then roll top over and then block of wood and mallet and tap lightly in the indentation, start from back corner work to each end
took me 4 mins a side
PostPosted: Fri Dec 16, 2011 8:25 pm
I use some timber, 2x1 pine, and support the door frame so it is solid before hitting/tapping the strip off with a couple of firm taps of the timber with a hammer
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
Users browsing this forum: Bing [Bot] and 256 guests
