Front hub nut 60ftlb?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=74654
Author:  haze blue 850 [ Sat Dec 17, 2011 2:45 pm ]
Post subject:  Front hub nut 60ftlb?
Greetings All.
Replacing front wheel bearings. (850 drum) with tapered type. Old manual I have say's front hub nut 60 ftlb. Was this for original roller type. Would it be the same for tapper bearings?
Also, the inner roller bearing had a huge circlip. I obviously bin that as I cant see the recess anymore.
Thanks
Alex.
Author:  Harley [ Sat Dec 17, 2011 3:03 pm ]
1. 60 ft/lb still applies: its the strength of the thread, not what its holding.
2. I've never seen a circlip on a bearing assembly in a mini, any more details on that?
Author:  haze blue 850 [ Sat Dec 17, 2011 3:15 pm ]
Thanks Harley.
I was worried about 'crushing" it, but thinking about it, I presume the new spacer stops that.
Just found the number of the circlip -21A1307- It describes it as a "Spacer". It sounds like it sets the oil seal at a specific spot. The new oil seal just bottoms out on the bearing cup.
Thanks again.
Alex
Author:  miniDave [ Sat Dec 17, 2011 3:15 pm ]
The circlip is really just a spacer to keep the inner seal in the correct position. There is no groove but I put it back in there when I did mine - (I think)
Author:  drmini in aust [ Sat Dec 17, 2011 3:17 pm ]
Is it a circlip, or the seal spacer (which looks like a piston ring).
Tapered rollers take a wider spacer, but you can run without it if careful fitting the seal.
Author:  haze blue 850 [ Sat Dec 17, 2011 3:29 pm ]
Thanks too Doc.
It sat in nice and square. I'll leave it off.
Now to the next side.
Last week coming home from work it was whinning like hell. I cleaned the roller bearings in petrol (just curious) and they were not as loose as i thought. They free spin and if I spin em fast enough, one has a funny vibration. Anyhow, tapers will be better and safer.
alex.
(Crap! The keyboards dirty. NoW I'm in trouble!)
