The flasher can wiring is the same for the right and left indicator, so this isolates the flasher can from the problem.
I can't solve it like this, but at least you can leave the flasher can out of the equation.
The contacts can indeed give trouble, as can the wiring from the contact to the bullet connectors or plug under the dash. The wires move around a lot as the arm moves and can fracture inside the insulate without looking broken. Another spot to check is the bullet connector on top of the speedo under the bonnet, check to see it is still connected and sweet. This bullet supplies the indicator to the front and rear and is another potential bottleneck.
If both front and rear bulbs are out all at once, then it is unlikely to be the bulbs or fittings at fault. Also the front and rear earths are common for right and left lights, so it won't be that if the other indicator side is working fine.
So I would check the contacts again using a multimeter to test for continuity at all times, and the bullet connectors and plugs.
_________________ SooperDooperMiniCooperExpertEngineering
