OK. My cabs are fine, but it idles really low https://www.ausmini.com/forums/viewtopic.php?f=2&t=74861 |
Author: | brett [ Wed Jan 04, 2012 7:07 pm ] |
Post subject: | OK. My cabs are fine, but it idles really low |
Normally, It idles at 800rpm... but its sitting at about 450rpm. We put a timing chain in, and since then I presume I have to adjust the dizzy.. do I have to move it left or right? to get it back to the RPM speed. Or do I have to adjust points?? Its running rough, but it does start and run |
Author: | dodge [ Wed Jan 04, 2012 8:58 pm ] |
maybe u put the timing gears out a few deg, try to turn the dizzy clockwise if u think its out, but turn the idol screw up first or u might damage something |
Author: | simon k [ Wed Jan 04, 2012 10:00 pm ] |
if it was good where the distributor is now, then there's no reason anything would need to be changed in that department... turn the idle screws up and go for a drive - you might find it's well down on power, if that's the case, pull the motor out again and check the cam timing |
Author: | brett [ Wed Jan 04, 2012 10:43 pm ] |
Yeah we marked it when we pulled the little cog off and fitted the chain. So going to adjust the distributor tommorrow. It runs just pops and carries on. |
