I have no probs bleeding single circuit ones. But when I reconditioned Barney's tandem one a few years ago I could only get around 1/2 a pedal.
I gave up, drove it to B&R Brakes and they power bled the bugger.
I've found the same thing over the years too Doc,,,
For those wondering.. a tip I have picked up along the way is, if Matt's method does not work, (yes sometimes it won't come out, unless you get the flow happening to begin with) (only on the tandem ones mind you this happens)
I crack the joints at the safety ball switch valve thingy,, no idea what they call it, bias valve? but anyway, the thing that saves/helps if you loose brakes to a wheel etc..,, which is bolted above the subframe tower.... this is why single master cyclinders have no trouble bleeding blind folded,, they don't have this.. it is located at the rear subframe
ANYWAY... yes I crack the joints/ brake lines going from the master cyclinder and into this valve.. get that flow happening tighten it all back up, and your laughing,, go have a few beers, and shall be done
Also if you look at the design of the shape of the pipe (the bend) coming out of the single and tandem master cylinders, they are different,, and one is higher than the other from the level of the fluid in the master cylinder..
One put's 2 and 2 together and will realise that crap won't flow up hill, until it gets a flow happening to begin with..
Those who have run outta fuel in a truck on the side of the road before and had to suck on a hose and taste how awesome diesel is, will know exactly what I mean
wow,, i think this is the most I have typed on here in bloody ages!! think I must have had too much to drink tonight!!
