It is currently Wed Aug 20, 2025 11:47 pm
PostPosted: Fri Jan 06, 2012 12:08 pm
might be some help one day.....i ended up with jetting ..specs..this is on a 1275 gt..bored out to1330.fully worked head..cam 648...has strait cut gearbox...valve springs...200lbs...jets as follows..p25..s27..main jet..p135..s..145..air corr jet p185..s165..idle jet..p50..s65..emulsion tube..p..f30..s..f30.....pump jet..70....pump valve 0...
