It is currently Mon Aug 18, 2025 4:22 am
 Post subject: Going back to 10''
PostPosted: Sun Jan 08, 2012 4:17 pm
I've decided I want to put my car back on a set of 10'' wheels as I'm sick of the sloppy 13x7's. I trying to work out if I'll have to weld some panels back on to fit a smaller flare or if I can just keep my current comp flares. Can any tell me what I'll need to do?
PostPosted: Sun Jan 08, 2012 4:43 pm
If you have the coin use some Rose Petal rims
http://www.minispares.com/Product.aspx?ty=pb&pid=42549
and if your worried about flares see if some Leyland Mini flares fit , also if you saying that you have cut your guards to make sure the 13x7 did,nt rub then you might have look at adding an edge to fit smaller flares , they will have to be welded on the internal side if the guard ( so as not to damage paint ) , small spot welds would be better
PostPosted: Sun Jan 08, 2012 5:11 pm
Just buy some fat tens in charcoal and lower the car, it'll look great.
:D
PostPosted: Sun Jan 08, 2012 6:21 pm
10x6 Minators look quite yummy with their bit of dish. 8)
PostPosted: Sun Jan 08, 2012 6:27 pm
You could go the Rat look with some 10x6 steelies in Matt Black.
:P :lol:
Dicko
PostPosted: Sun Jan 08, 2012 7:21 pm
If I can just drop it on 10x6 I will but I'm worried that the amount that has been cut out will look awkward. I need to try first..
Rose petals are by far my favourite wheels but I think they need to be run with no flares at all
PostPosted: Mon Jan 09, 2012 5:14 pm
I've got chromed 10 x 7 steels with spun halves (only one weld) on my 1970 Mk2 Cooper S and had to cut the front guards a little at the leading edge to get clearance. I have Group 2 extensions fitted (same as Manton had on his last Mini) which cover things ok.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Jan 09, 2012 5:29 pm
Hey Slide, any chance of pics? Sounds tres noice.
PostPosted: Tue Jan 10, 2012 11:33 am
Yeah a pic would be very helpful
PostPosted: Tue Jan 10, 2012 1:49 pm
Out of interest sake, whats the widest 12's come in?
Woulndt say 12x6 fill the modified guards better but give less sloppy ride than with the 13s?
PostPosted: Tue Jan 10, 2012 2:09 pm
Supercharged
10x6 minators will still sit out of those flares and allow a drop in ride height for that premium look.
check the offset.
PostPosted: Tue Jan 10, 2012 2:43 pm
I had these 10x6 on my Mini and they sometimes touched at the front of the guard when turning.
http://www.ausmini.com/forums/viewtopic.php?t=74902
They stuck out quite a bit so would still fit your wider arches quite well I think
If you want to try you are welcome, no pressure to buy mine.
PostPosted: Tue Jan 10, 2012 3:43 pm
I'm keen to go for a 10'', just love the look of small chubby wheels. From what I'm seeing the 10x6 will look fine.
Now... which ones :D
PostPosted: Tue Jan 10, 2012 3:48 pm
I did see these in the forsale section. Not quite what I'm looking for :( they look like a different offset??
PostPosted: Tue Jan 10, 2012 3:52 pm
you cant beat 10x6 with the right offset.
100% Pure A Series Turbo
Users browsing this forum: No registered users and 337 guests
