It is currently Sun Aug 17, 2025 3:37 pm
PostPosted: Fri Nov 25, 2011 12:33 pm
Hi guys,
Is it possible that a worn primary gear bush could cause an engine vibration over about 3000 rpm and a lowering of oil pressure. Cause I have these symptoms and have found bronze coloured shavings in the sump, lots of them!
Thanks in advance.
Richard.
PostPosted: Fri Nov 25, 2011 12:44 pm
Mods rock!
bluewhitecoopers1968 wrote:
Hi guys,
Thanks in advance.
Richard.
You really wouldn't see Primary Gear Bush material in the sump. Sorry to say it sounds more like Crank Bearings, Mains and / or Thrust and / or Big Ends.
PostPosted: Fri Nov 25, 2011 2:06 pm
bronze (brass) shavings could also be coming from the diff spider gear washers....
engine out!
PostPosted: Fri Nov 25, 2011 2:07 pm
engine out!
You do mean copper, Simon, you are close. :P
PostPosted: Fri Nov 25, 2011 2:14 pm
probably center main brg (at least)
maybe cracked crank too
rip it out & apart
PostPosted: Fri Nov 25, 2011 2:16 pm
engine out!
missed it by *that much* :D
PostPosted: Sat Nov 26, 2011 7:15 am
Yeah it is actually bronze or copper chips in the sump, engine out again I guess :D at least its nice and cool this weekend.
PostPosted: Sun Nov 27, 2011 6:43 pm
UPDATE....
Well the engine is out and I found a couple of problems, 1) the diff is loose as s*it, and the main bearing has spun. Looks like the copper chips were from the thrust bearings on the mains.
Thats as far as i've got to date. I will have to ponder this for a few days
PostPosted: Sun Nov 27, 2011 6:53 pm
Mods rock!
UPDATE....
Pardon the french, but Oh crap. Sorry to learn of this.
PostPosted: Sun Nov 27, 2011 6:59 pm
UPDATE....
Thanks mate, I just hope the crank aint too bad :D
PostPosted: Sun Nov 27, 2011 7:04 pm
Mods rock!
UPDATE....
Fair enough, but I'd be really really worried about the block (and cap). Will probably need facing and then line boring to put it right. If the Crank is an EN40B and still has Nitriding it has a good chance of being OK, but in any event, most likely nothing that a straight forward grind won't fix.
PostPosted: Sun Nov 27, 2011 7:08 pm
UPDATE....
I'll just have to see when I pull the crank out, the cap looks ok though, cross fingers.
PostPosted: Sun Nov 27, 2011 7:55 pm
Check the crank's endfloat when you reassemble it. The factory spec of .003" is NOT enough if you are going to rev it. I found out the hard way... it starves the centre main of oil flow, then the shells spin.
You want .006" endfloat at least on a revvy 1275. Because the crankwebs flex.
PostPosted: Sun Nov 27, 2011 9:27 pm
sh*tballs!
did you do anything to cause it, or did it just happen?
PostPosted: Mon Nov 28, 2011 4:03 pm
simon k wrote:
sh*tballs!
Well yeah I suppose too many revs, I noticed an engine vibration on the way home from a club sprint in tamworth.
http://www.youtube.com/tech160s#p/a/u/0/3PVASc6GKqc
:D :D :D
Users browsing this forum: No registered users and 349 guests
