mini tool box https://www.ausmini.com/forums/viewtopic.php?f=2&t=74952 |
Author: | slacko [ Wed Jan 11, 2012 5:00 pm ] |
Post subject: | mini tool box |
Going to put together a tub to put in the boot of stuff that I hope I will not have to use , but just in case What do mini owners carry with them ? Just in case Mark |
Author: | Harley [ Wed Jan 11, 2012 5:08 pm ] |
Mobile phone. ![]() I guess if you wanted though, you could carry tape, wd40, water, oil, screwdrivers, 1/2in ring spanner, jumper cables and some rags. Or you could be like some people on here and carry essentially a whole engine less the block with you! ![]() |
Author: | slacko [ Wed Jan 11, 2012 5:14 pm ] |
Bugger Don"t have a spare motor ![]() Wounder if Dr mini will fit in the boot ![]() |
Author: | danny_ [ Wed Jan 11, 2012 5:18 pm ] |
I carry: Fence wire WD40 several rolls of electrical tape and gaffer tape 1/4" Socket set spanner set in roll up bag spare crank sensor spare o2 sensor gasket maker rover SPI fuel trap 2mtrs of vacuum tube and a couple of elbow connectors The little retaining clip that goes to the temp fan switch in the radiator couple of spare wheel nuts jack leatherman small inspection mirror NRMA card water Oil SPI ECU (only if i am really paranoid) Jump starter The boot is pretty much full all the time. |
Author: | slacko [ Wed Jan 11, 2012 5:22 pm ] |
WOW ! ![]() |
Author: | DA9jeff [ Wed Jan 11, 2012 6:55 pm ] |
WD40 & Duct Tape IF something moves that shouldn't... Duct Tape If something doesn't move that should... WD40 ![]() ![]() |
Author: | drmini in aust [ Wed Jan 11, 2012 7:13 pm ] |
set of short Indian OE spanners pliers longnose pliers multigrips 2 shifters- 4" and 6" couple of screwdrivers 4 way wheel brace 6 cable ties various sizes WD40 feeler gauges Mini jack 4 new sparkplugs socket set (old small Sidchrome one) |
Author: | goodie [ Wed Jan 11, 2012 9:44 pm ] |
I carry pretty much the same as Doc , as well as some electrical wire , joiners and crimpers , a spare set of points , even have an old 12 volt soldering iron, ![]() tackle box . |
Author: | min-E [ Thu Jan 12, 2012 5:07 am ] |
DA9jeff wrote: WD40 & Duct Tape
IF something moves that shouldn't... Duct Tape If something doesn't move that should... WD40 ![]() ![]() ![]() ![]() ![]() |
Author: | blue_deluxe [ Thu Jan 12, 2012 12:02 pm ] |
I didnt carry anything in my boot. Sods law states that no matter how much you carry the thing that breaks will be the one thing you didn't have the parts for. |
