Trottle Cable Length
https://www.ausmini.com/forums/viewtopic.php?f=2&t=74978
Author:  goodie [ Fri Jan 13, 2012 9:27 am ]
Post subject:  Trottle Cable Length
Does someone have a brand new mini throttle cable in their stash , that they could measure the outer and inner cable length for me ?
I'm led to believe that there are 2 different length cables that you can get ,
I E ; standard length , and an extended length .
Reason i ask is i'm thinking about changing my cable , ( which has been in the car , 18 yrs :shock: ) and i have spotted a Teflon Lined cable that suits a go - kart .
Can't see why it wouldn't work . Cheap too !
Thanks , Colin .
Author:  adios57 [ Fri Jan 13, 2012 3:12 pm ]
I ended up with a short one which meant I had to leave off the new accelerator pedal stop and the old one for that matter. :?
Author:  Morris 1100 [ Fri Jan 13, 2012 3:57 pm ]
I have a new one here that I got from a Mini shop a while back, the outer is 66cm long, the inner is 88cm long. It has a couple of part number stickers on it...
QTC4006
MTC309
AYA2179 (this is actually the Australian Morris 1100 part number, the Australian part number for the Mini is AYA2134)
Author:  GT mowog [ Fri Jan 13, 2012 4:46 pm ]
Hi Goodie,
The long one is 750 / 900 mm.
Cheers mate :)
Author:  goodie [ Fri Jan 13, 2012 9:08 pm ]
Thanks very much for that people , very helpful , i didn't want to have to pull mine out just to measure it , and then have to put it back in again until i got a new one .
Author:  Morris 1100 [ Fri Jan 13, 2012 9:10 pm ]
Measure the outer with a bit of string or wool. :wink:
Author:  goodie [ Fri Jan 13, 2012 9:17 pm ]
Yeah Morris , not a bad idea .
