It is currently Sun Aug 17, 2025 10:21 am
PostPosted: Mon Jan 16, 2012 7:19 am
Hi All,
Has anyone had any issues with the A+ electronic dizzy (lucas???)?
Have this fitted to the express & the module on the side has been changed twice already (in less than 2 years) and this weekend after fully rebuilding the engine & re-fitting it to the car it sh*t itself again!
Basically it stalls the engine - cuts all power & engine stalls; other times it just breaks down as though the timing is all over the place.
If anyone has had similar issues & or knows a way to rectify this without replacing the module (ie bypassing it) let me know.
Cheers, Bryan
1964 Morris 850 and some!!
PostPosted: Mon Jan 16, 2012 8:01 am
What coil are you running?
If dizzy is a 65DM4 , from memory the correct coil should be about 0.7 ohms.
Cheers.
Now with 2 extra ports!
Users browsing this forum: No registered users and 261 guests
