It is currently Sun Jul 27, 2025 3:52 pm
 Post subject: Front Disks
PostPosted: Wed May 25, 2005 10:56 am
Gday Guys
I was just wondering how hard it is to get my hands on some front disks??
and how much i would be looking at for a set??
and also how hard is it to install/or would it be easier to get the pro's to install it??
Thanks Guys
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Wed May 25, 2005 11:07 am
Depend on what you want to put on.
If you want to get Mini Cooper 7 of 7.5" ones they are harder to get and cost $$$$
Or you counld to a Honda Dics conversion like some other have done and they are cheaper and work better.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed May 25, 2005 11:11 am
I reckon if I had a dollar for every time this has been asked, I could buy some 'S' discs (for up to $1500) or 2 sets of LS discs (for around $600 each)
:lol: :lol:
Get it?? I answered your question AND put sh!t on you for asking a common question, all in the one reply! :lol:
EDIT: Doogie has S discs, ready to bolt in, for $1300 - see the FOR SALE section :wink:
PostPosted: Wed May 25, 2005 11:12 am
What size disks?
If you are after 7.5" cooper S disks then it is hard to find then and they will cost you quite a bit advantage is they fit under 10" wheels. Your looking upwards of $1000 for a good set unless you are lucky
Fitting S discs is easy once you have all the parts.
if you want 8.4" disks which suit 12" and bigger wheels then these are a bit cheaper and easier to find it is also possible to mod camira, honda, or some other disks to fit under 12" rims.
8.4" disk I am not sure how much they cost but I am guessing in the order of $600 - $800 they other types of disks need to be modded and unless you have access to lathes and milling machines and know how t use them I dare say that is best left to professionals.
I magine once these discs have been modded they are easy enough to fit.
with all of the discs they will need higher brake pressures to work this means that your rear drum brakes will tend to lockup before the fronts come into action. To solve this you can either fiddle about with the brake bias valve on the rear subframe or the better way is to get cooper s rear wheel cylinders and install these in your rear drum brakes.
Fitting of brake boosters is optional :wink:
Roads need more corners
PostPosted: Wed May 25, 2005 11:58 am
don't forget 5/8 rear wheel cylinders to prevent unwanted rear wheel lockups.....
PostPosted: Wed May 25, 2005 12:11 pm
I can sell my set of 8.4 disks for sale... I need to get 4-pots or custom ones for my car now... stopping could be good
Baracade
