electronic ignition - module issues https://www.ausmini.com/forums/viewtopic.php?f=2&t=75023 |
Author: | nullarbor express [ Mon Jan 16, 2012 7:19 am ] |
Post subject: | electronic ignition - module issues |
Hi All, Has anyone had any issues with the A+ electronic dizzy (lucas???)? Have this fitted to the express & the module on the side has been changed twice already (in less than 2 years) and this weekend after fully rebuilding the engine & re-fitting it to the car it sh*t itself again! Basically it stalls the engine - cuts all power & engine stalls; other times it just breaks down as though the timing is all over the place. If anyone has had similar issues & or knows a way to rectify this without replacing the module (ie bypassing it) let me know. Cheers, Bryan |
Author: | SuperCooper [ Mon Jan 16, 2012 8:01 am ] |
What coil are you running? If dizzy is a 65DM4 , from memory the correct coil should be about 0.7 ohms. Cheers. |
