It is currently Fri Jul 18, 2025 11:34 am
PostPosted: Wed Jan 18, 2012 9:36 pm
Finally worked out the odd knock knock noise from the front end, I have 2 busted wheel studs 1 nut has gone, I found out by checking the wheel nut tension, 2 ok one 'snapped off' with very little tension and the 4th is 'somewhere on the road'!
So, I can buy a new set of nuts for 30 GBP plus some postage, but I actually only need one. The same as in my sig.
Any ideas where I can buy them single?
Yes maybe this should go in 'wanted' now shouldn't it!
Cool stuff!!
PostPosted: Thu Jan 19, 2012 2:17 pm
Have you tried Andrew at Minisport, they sell the wheels so may have the nuts.
Cheers Pete
