It is currently Tue Aug 19, 2025 6:29 pm
 Post subject: Oil and Temp Sender Size
PostPosted: Wed Jan 18, 2012 11:18 am
Hi, what size are the oil and temp senders as I got some gauges for Xmas and am not sure if they will be a straight swap. If not where is the best place to get an adaptor?
Cheers James
1962 Traveller with 1275LS engine
PostPosted: Wed Jan 18, 2012 12:00 pm
Oil sender hole is 1/8 BSP.
Temp sender hole in the head is 5/8-18 UNF.
If you get stuck on the temp adaptor I can make you a brass one, if you can tell me what the sender thread is (probably is 1/8 NPT these days).
PostPosted: Wed Jan 18, 2012 7:28 pm
Thanks Doc, I might have to take you up on that if I cannot source one locally. They are both 1/8 npt can I use the oil pressure without an adaptor?
PostPosted: Wed Jan 18, 2012 7:41 pm
The 1/8 NPT oil pressure sender will screw in a bit, it might be OK.
The 2 thread sizes are close, but no cigar.
NPT is slightly bigger than BSP- and it's 27TPI not 28.
Try it and see if it leaks- but if you want to make it right, send to me and I'll run a 1/8 BSP die down it. :wink:
Users browsing this forum: No registered users and 482 guests
