Oil reaction
https://www.ausmini.com/forums/viewtopic.php?f=2&t=7508
Author:  Mick [ Tue May 24, 2005 5:29 pm ]
Post subject:  Oil reaction
Does anyone hear of oils reacting with each other and blocking oilways anymore?
I know this used to be a bad issue with the oil galleries slowly blocking up over time.
I was wondering if this still exists with new oils.
Author:  68matic [ Tue May 24, 2005 6:07 pm ]
either way i wouldnt be mixing oil brands.
maybe within an oil brand maybe
trev has penrite classic medium, he started sounding a little loud when warm, so i top up with classic heavy
Audie who sells it to me said its fine
Author:  drmini in aust [ Tue May 24, 2005 8:12 pm ]
I think you are pretty safe with mineral oils, I wouldn't mix synthetic oil with it though.
Original Castrol R (castor oil based) had a reputation for blocking things up many years ago if you left it standing too long in a motor, but that stuff was just a race oil. Lovely smell though... 8)
Author:  Mini Mad [ Tue May 24, 2005 9:02 pm ]
I've mixed plenty of oils of the same weight over my time...
Author:  Mick [ Tue May 24, 2005 9:11 pm ]
So for instance, you wouldn't swap back and forth using a semi-synthetic oil to a straight mineral oil? Or do you mean full synth to a mineral perhaps?
I've been sticking with Penrite since building this 1275 eight years back, and have had a clean, reliable and easy to keep cool engine.
I would like to try another oil, simply out of curiosity more than anything else but I've seen the results of this when the Navy changed it's oil throughout the fleet a decade or so back. They ended up with gummed up oilways and all kinds of problems resulting from the swapping and mixing of oil in it's big diesels.
I thought maybe it was an issue that might have been sorted by now accross the industry.
Author:  min13k [ Tue May 24, 2005 9:13 pm ]
mick stick with what works
makka
Author:  Mini Mad [ Tue May 24, 2005 9:19 pm ]
I meant Mineral...I don't use synthetic in the mini..
For instance, the other day i topped up some Castrol Forumla R 20w50 with Valvoline XLD 20w50...since the lovely A-series has started an appetite for oil :)
Motor's on it's last legs..if it was new, i would prefer not to mix oil, but it certainly does no harm IMO..
