1275LS motors? https://www.ausmini.com/forums/viewtopic.php?f=2&t=75123 |
Author: | Bubbacluby [ Sat Jan 21, 2012 9:22 pm ] |
Post subject: | 1275LS motors? |
A lad was trying to say that 1275LS's came standard with a+ motors. This lads a real loser, so I dont believe him but can someone confirm/deny this? Cheers Brenton |
Author: | drmini in aust [ Sat Jan 21, 2012 9:25 pm ] |
They had so-called A+ timing covers (with tensioner) and A+ rockers, 12G1316 smog head, that is all... block [edit- and the whole bottom end] is A series. I believe the late 1275 Mokes got A+, I had one in Barney. |
Author: | Mokesta [ Sat Jan 21, 2012 9:38 pm ] |
Some late Mokes got A+ gear sets on non-A+ blocks (well the 998 one I bought had that combo anyway). |
Author: | michaelb [ Sat Jan 21, 2012 9:44 pm ] |
What the doc said. And they had heavy conrods with counterweights |
Author: | Morris 1100 [ Sun Jan 22, 2012 9:17 am ] |
The 1275LS block is not the same as an 1100S block but it is not an A+ block. My 1275LS motor has the timing cover with the hump for the tensioner but there is no tensioner in it. I don't know if it was ever fitted, I can't remember seeing any signs of it. |
Author: | poeee [ Sun Jan 22, 2012 9:19 am ] |
They have an A+ layshaft in the box, too? |
Author: | Morris 1100 [ Sun Jan 22, 2012 9:40 am ] |
Mine had the big bearing drop gears and the later layshaft box. But the motor had signs of being blown up (one odd con-rod and a few scars on the block) so there is a chance the box may have been changed. I got the car in 1984 so anything could have been changed in those first six years. |
Author: | TheMiniMan [ Sun Jan 22, 2012 10:58 am ] |
The 1275LS`s weren`t meant to have A+ boxes,,, not saying that some weren`t fitted with them, but i suspect it would have been very very very rare,,, (notice i used 3x "very"`s there) the late mokes got A+ boxes & donks for sure but the LS`s were pretty much the (What i call) "Inbetweeny" blocks ,,, as in inbetween 1100S blocks & A+ blocks -->(As morris 1100 said with the lump in the block for the extra bolt for the tensioned "Type" blocks but no extra webs like the A+ got) & not "ALL" of them were even "inbetweeny" blocks either, early ones were just like 1100S blocks but with LS numbers stamped |
Author: | Bubbacluby [ Sun Jan 22, 2012 12:06 pm ] |
Ok thanks everyone, thought i was right and the lad was just producing what usually comes out of his mouth. Next time he says it i can tell him what for ![]() ![]() Thanks everyone Brenton |
Author: | GT mowog [ Sun Jan 22, 2012 2:24 pm ] |
The A+ Engine was developed for the Metros. The Gearboxes first appeared in the UK very late in 78, the engines mid to late 79. The Mokes didn't see the A+ Gearboxes until ~Sept / Oct 79 and the A+ Engines until Oct / Nov 79. One of my Mokes had A+ Gearbox, pre A+ Block and A+ Rods. This one was plated October 1979. I bought it with 8 000km on the clock. It was as it came from the factory. The 1275 LS's were too early, only just, for the A+ stuff. |
